Problem with reconnect wifi
Hey, guys! I'm having a problem that I don't know why or if there is a solution. When I run the skecth below on ESP32 with broadband internet in my house, the wifi connects and if I disconnect and reconnect the connection, it reconnects automatically. But, if I use the 4g internet routed from my Smartphone, the wifi connects, but if I disconnect and connect again, it still appears as "disconnected" and WiFi.status() goes from 6 to 0, which respectively is : WL_DISCONNECTED and WL_IDLE_STATUS and does not connect again.
#include <WiFi.h>
  WiFi.begin("mywifi", "password");
  if(WiFi.status() == WL_CONNECTED)
    Serial.println("CONNECTED");
    Serial.println("DISCONNECTED");
    Serial.print("STATUS: ");
    Serial.println(WiFi.status());
Does anyone know why the same code behaves differently on different networks?
I don't know if the problem could be the ESP hardware, the router or the actual code...
I tried to look for situations similar to mine, there are several reports but no conclusion or solution.
Thanks!
Someone?
