Everytime i compile even a basic file for arduino 101 it shows a message for redefinition of void loop
this is the error i get
C:\Users\George\Desktop\Arduino\libraries\LiquidCrystal\examples\HelloWorld\HelloWorld.ino: In function 'void loop(...)':
HelloWorld:53: error: redefinition of 'void loop(...)'
In file included from c:\users\george\appdata\local\arduino15\packages\intel\tools\arc-elf32\1.6.4+1.0\arc-elf32\sys-include\sys\config.h:5:0,
from c:\users\george\appdata\local\arduino15\packages\intel\tools\arc-elf32\1.6.4+1.0\arc-elf32\sys-include_ansi.h:16,
from c:\users\george\appdata\local\arduino15\packages\intel\tools\arc-elf32\1.6.4+1.0\arc-elf32\sys-include\stdlib.h:11,
from C:\Users\George\AppData\Local\Arduino15\packages\Intel\hardware\arc32\1.0.5\cores\arduino/Arduino.h:24,
from C:\Users\George\AppData\Local\Temp\builded69793b6932109a9bdacbf180af5d05.tmp\sketch\HelloWorld.ino.cpp:1:
c:\users\george\appdata\local\arduino15\packages\intel\tools\arc-elf32\1.6.4+1.0\arc-elf32\sys-include\sys\features.h:210:6: error: 'void loop(...)' previously defined here
Using library LiquidCrystal at version 1.0.5 in folder: C:\Users\George\Desktop\Arduino\libraries\LiquidCrystal
exit status 1
im not sure but it keep telling me that the void loop has already been defined in the features.h file
can anyone help with this problem??
here is the basic code im using...
LiquidCrystal Library - Hello World
Demonstrates the use a 16x2 LCD display. The LiquidCrystal
library works with all LCD displays that are compatible with the
Hitachi HD44780 driver. There are many of them out there, and you
can usually tell them by the 16-pin interface.
This sketch prints "Hello World!" to the LCD
and shows the time.
The circuit:
- LCD RS pin to digital pin 12
- LCD Enable pin to digital pin 11
- LCD D4 pin to digital pin 5
- LCD D5 pin to digital pin 4
- LCD D6 pin to digital pin 3
- LCD D7 pin to digital pin 2
- LCD R/W pin to ground
- LCD VSS pin to ground
- LCD VCC pin to 5V
- 10K resistor:
- ends to +5V and ground
- wiper to LCD VO pin (pin 3)
Library originally added 18 Apr 2008
by David A. Mellis
library modified 5 Jul 2009
by Limor Fried (http://www.ladyada.net)
example added 9 Jul 2009
by Tom Igoe
modified 22 Nov 2010
by Tom Igoe
This example code is in the public domain.
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print("hello, world!");
// set the cursor to column 0, line 1
// (note: line 1 is the second row, since counting begins with 0):
lcd.setCursor(0, 1);
// print the number of seconds since reset:
lcd.print(millis() / 1000);
