Problem with relay board
Hi all, I just received my relay board ,(took almost a month to get) and I have problems with the hookup. I know ground(gnd) and 5 volt power supply(vcc) where they go but that's where my problem comes into play. In1, In2, In3,and In4 work backwards. On my arduino say analog pin A1 turns on a light in my program, once it sends the 5 volts nothing happens. It will work only when no power is on that terminal. The board works off a ground for those terminal. I want to know if this is normal or did I purchase the wrong board. Here's the board, http://www.ebay.com/itm/Four-4-Channel-5V-Relay-Module-Expansion-Board-For-Arduino-PIC-AVR-ARM-MCU-DSP-/160756264564?pt=LH_DefaultDomain_0&hash=item256dd1ee74#ht_5474wt_932
Any help would be appreciated.
For that board design that is normal operation. a LOW on a channel input will activate a relay, a HIGH will deactivate the relay. That is not a problem, but rather just something you need to be aware of as you write your sketch programs that use the board.
PS: You should not think or talk of arduino digital outputs as '5 volts' and 'no power', but rather as HIGH and LOW logic levels.
Lefty
