I am using three solenoids, activated by TIP 120 transistors, and one pump activated by a 5V relay (I had a 4-channel module laying around but I only need one channel of it). I am using millis timer function instead of delay. The solenoids activate and are timed just fine. The pump does not activate except with Solenoid #3 the pump activates but the timing does not work, it turns off immediately when a sensor value drops below a set point. The code for the solenoids and the relay to activate the pump is the same. I don't understand why the relay is not activating, can anyone help please?
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int up = 7;
int down = 8;
int alt = 6;
int mode = 9;
int moisture1 = A0;
int moisture2 = A1;
int moisture3 = A2;
int valve1 = 0;
int valve2 = 10;
int valve3 = 13;
int pump = 1;
int pumpstate = HIGH;
int valvestate1 = LOW;
int valvestate2 = LOW;
int valvestate3 = LOW;
int lvl1 = 0;
int lvl2 = 0;
int lvl3 = 0;
int vary = 0;
int cycle = 1;
int u1; // variable for reading the pin status
int u2; // variable for reading the delayed status
int uState; // variable to hold the button state
int d1;
int d2;
int dState;
int a1;
int a2;
int aState;
int m1;
int m2;
int mState;
unsigned long settime1 = 0;
unsigned long settime2 = 0;
unsigned long settime3 = 0;
unsigned long timer1 = 0;
unsigned long timer2 = 0;
unsigned long timer3 = 0;
pinMode(up, INPUT);
pinMode(down, INPUT);
pinMode(alt, INPUT);
pinMode(mode, INPUT);
pinMode(moisture1, INPUT);
pinMode(moisture2, INPUT);
pinMode(moisture3, INPUT);
pinMode(valve1, OUTPUT);
pinMode(valve2, OUTPUT);
pinMode(valve3, OUTPUT);
pinMode(pump, OUTPUT);
lcd.begin(16, 2);
uState=digitalRead(up);
dState=digitalRead(down);
aState=digitalRead(alt);
mState=digitalRead(mode);
digitalWrite(pump, pumpstate);
digitalWrite(valve1, valvestate1);
digitalWrite(valve2, valvestate2);
digitalWrite(valve3, valvestate3);
int moistureval1 = analogRead(moisture1);
moistureval1 = map(moistureval1, 0, 1023, 0, 100);
int moistureval2 = analogRead(moisture2);
moistureval2 = map(moistureval2, 0, 1023, 0, 100);
int moistureval3 = analogRead(moisture3);
moistureval3 = map(moistureval3, 0, 1023, 0, 100);
settime1 = constrain(settime1, 0, 300);
lvl1 = constrain(lvl1, 0, 100);
settime2 = constrain(settime2, 0, 300);
lvl2 = constrain(lvl2, 0, 100);
settime3 = constrain(settime3, 0, 300);
lvl3 = constrain(lvl3, 0, 100);
if ((moistureval1 > 5)&&(moistureval1 < lvl1)&&(pumpstate == HIGH)){
pumpstate = LOW;
valvestate1 = HIGH;
timer1 = millis();
if ((millis() - timer1) >= settime1*1000){
pumpstate = HIGH;
valvestate1 = LOW;
if ((moistureval2 > 5)&&(moistureval2 < lvl2)&&(pumpstate == HIGH)){
pumpstate = LOW;
valvestate2 = HIGH;
timer2 = millis();
if ((millis() - timer2) >= settime2*1000){
pumpstate = HIGH;
valvestate2 = LOW;
if ((moistureval3 > 5)&&(moistureval3 < lvl3)&&(pumpstate == HIGH)){
pumpstate = LOW;
valvestate3 = HIGH;
timer3 = millis();
if ((millis() - timer3) >= settime3*1000){
pumpstate = HIGH;
valvestate3 = LOW;
m1=digitalRead(mode);
delay(10);
m2=digitalRead(mode);
if (m1 == m2) {
if (m1 != mState){
if (m1 == LOW) {
if (cycle == 1){
cycle = 2;
else {
if (cycle == 2){
cycle = 3;
else {
if (cycle == 3){
cycle = 1;
mState = m1;
a1=digitalRead(alt);
delay(10);
a2=digitalRead(alt);
if (a1 == a2) {
if (a1 != aState){
if (a1 == LOW) {
if (vary == 0){
vary = 1;
else {
if (vary == 1){
vary = 0;
aState = a1;
if (cycle == 1){
lcd.setCursor(0, 0);
lcd.print("Sensor %");
lcd.setCursor(8, 0);
lcd.print("1");
lcd.setCursor(12, 0);
lcd.print(moistureval1);
//up button controls time
if (cycle == 1 && vary ==0) {
lcd.setCursor(0, 1);
lcd.print("Set On Time s");
lcd.setCursor(12, 1);
lcd.print(settime1);
u1=digitalRead(up);
delay(10);
u2=digitalRead(up);
if (u1 == u2) {
if (u1 != uState) {
if (u1 == LOW) {
settime1 += 15;
uState = u1;
//down button controls time
d1=digitalRead(down);
delay(10);
d2=digitalRead(down);
if (d1 == d2) {
if (d1 != dState) {
if (d1 == LOW) {
settime1 -= 15;
dState = d1;
if (cycle == 1 && vary ==1) {
//up button controls lvl
lcd.print("Set On Lvl %");
lcd.print(lvl1);
u1=digitalRead(up);
delay(10);
u2=digitalRead(up);
if (u1 == u2) {
if (u1 != uState) {
if (u1 == LOW) {
lvl1 += 5;
uState = u1;
//down button controls lvl
delay(10);
if (d1 == d2) {
if (d1 != dState) {
if (d1 == LOW) {
lvl1 -= 5;
dState = d1;
if (cycle == 2){
lcd.print("2");
lcd.print(moistureval2);
if (cycle == 2 && vary ==0){
lcd.print(settime2);
u1=digitalRead(up);
delay(10);
u2=digitalRead(up);
if (u1 == u2) {
if (u1 != uState) {
if (u1 == LOW) {
settime2 += 15;
uState = u1;
delay(10);
if (d1 == d2) {
if (d1 != dState) {
if (d1 == LOW) {
settime2 -= 15;
dState = d1;
if (cycle == 2 && vary ==1) {
lcd.print(lvl2);
u1=digitalRead(up);
delay(10);
u2=digitalRead(up);
if (u1 == u2) {
if (u1 != uState) {
if (u1 == LOW) {
lvl2 += 5;
uState = u1;
delay(10);
if (d1 == d2) {
if (d1 != dState) {
if (d1 == LOW) {
lvl2 -= 5;
dState = d1;
if (cycle == 3){
lcd.print("3");
lcd.print(moistureval3);
if (cycle == 3 && vary ==0) {
lcd.print(settime3);
u1=digitalRead(up);
delay(10);
u2=digitalRead(up);
if (u1 == u2) {
if (u1 != uState) {
if (u1 == LOW) {
settime3 += 15;
uState = u1;
delay(10);
if (d1 == d2) {
if (d1 != dState) {
if (d1 == LOW) {
settime3 -= 15;
dState = d1;
if (cycle == 3 && vary ==1) {
lcd.print(lvl3);
u1=digitalRead(up);
delay(10);
u2=digitalRead(up);
if (u1 == u2) {
if (u1 != uState) {
if (u1 == LOW) {
lvl3 += 5;
uState = u1;
delay(10);
if (d1 == d2) {
if (d1 != dState) {
if (d1 == LOW) {
lvl3 -= 5;
dState = d1;
Moderator edit: name of company selling counterfeit Arduino products removed
