Problem with Reset/upload the new program to Arduino Uno Rev3-Main Board
After I've used the Xbee modules for the wireless communication between two Arduinos, and both of the arduinos now are unable to upload new new program or reset it. some says that is the problem from my serial communication port as i connected the Rx(digital pin 0) and Tx(digital pin 1) to my Xbee modules.
// code of sender (Arduino 1)
Serial.println("H"); //turn on the LED
Serial.println("L");//turn off the LED
// code of receiver (arduino 2)
char msg = ' '; //contains the message from arduino sender
const int led = 13; //led at pin 13
Serial.begin(9600);//Remember that the baud must be the same on both arduinos
pinMode(led,OUTPUT);
while(Serial.available() > 0) {
msg=Serial.read();
if(msg=='H') {
digitalWrite(led,HIGH);
if(msg=='L') {
digitalWrite(led,LOW);
"Don't use pin 1 or pin 0, because these are used to communicate with the USB and thus into the computer.
Just disconnect the circuitry from pin 1 and you should be OK". by Grumpy_Mike http://forum.arduino.cc/index.php/topic,25714.0.html
But i tired to disconnect all the circuitry on my arduino, and it doesn't work as well.....please give me some solution for this....much appreciated for the helpss...
