Hello. I have a problem with communication between RF modules (FS1000A) and RadioHead library.
When receiver and transmitter placed near to each other (3-5 cm), it works. Large distance does not allow to transmit. I checked signal on receiver (when transmitter disabled), and I saw that voltage randomly changes from 0 to 3.7 v. I connect antennas to both modules (it's length about 17 cm). How to solve my problem?
Hi, the transmitters will take up to 12V on the VCC line, using greater than 5V on the VCC pin on your transmitter will increase range.
I used them on my own project but have since started using the nRF24L01 transceivers as they work on 5V and you don't need to solder antennae (mine came with rubber antennae).
