problem with right shifting bits???
I have a 16 bit variable and I want to read the high byte as an 8-bit value. I tried right shifting by 8 bits and casting the value as a uint8_t type. But I do not get the correct value, at least I don't get what I was expecting.
Here is some code:
  uint16_t dataLength, dataLength2;
  dataLength = 0x017F;
  Serial.println(dataLength, HEX);
  dataLength2 = dataLength >> 8;
  Serial.println  (((dataLength2),HEX));
  Serial.println((uint8_t) dataLength, HEX);
I expected to get 0x01 as the high byte value, but I am getting 0x16!!! What am I doing wrong with this seemingly simple operation?!?
-Tony
You have bad brackets in
which leads to a warning
Somewhere\AppData\Local\Arduino15\packages\arduino\hardware\avr\1.6.21\cores\arduino/Print.h:30:13: warning: left operand of comma operator has no effect [-Wunused-value]
If you drop them, everything works as expected.
  Serial.begin(250000);
  Serial.println((dataLength2), HEX);
void loop() {}
17F
1
7F
Thanks! That was weird. I got no warnings from the compiler. That fixed it!!
By default, the compiler warnings are turned off - I suspect the reason is to keep hoards of people from seeing a warning that isn't a problem (since we're all copy-pasting half-assed code all over, which is often full of stuff that gets warnings) and screaming on forums about the warnings, not knowing the difference between a warning and an error.
Anyone whose sketch is not doing what they expect should turn up their warning level to ALL. Often that will put out a warning that indicates a common coding mistake that isn't technically an error.
How about:
  uint16_t dataLength;
  Serial.println(highByte(dataLength),HEX);
  Serial.println(lowByte(dataLength),HEX);
void loop(){}
Arhodes01075:
No, you are getting 16 :wink:
Serial.print() don't print leading zeros, 0x01 prints 1. Try:
  if(highByte(dataLength) < 0x10)
    Serial.print('0');
  if(lowByte(dataLength) < 0x10)
    Serial.print('0');
void loop(){}
