#include <IRremote.h>
int receiver = 11; // pin 1 of IR receiver to Arduino digital pin 11
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results;
#define dir_1 46
#define pwm_1 3
#define dir_2 47
#define pwm_2 2
int STATE=1;
int Arming_Time=0;
int pin=9;
int Pulse=1000;
int triggerPort = 53;
int echoPort = 52;
int triggerPort1 =51 ;
int echoPort1 = 50;
int triggerPort2 =48 ;
int echoPort2 = 49;
byte speed = 125;
void setup(){
pinMode(pin, OUTPUT);
for(Arming_Time=0;Arming_Time<500;Arming_Time+=1)
digitalWrite(pin,HIGH);
delayMicroseconds(1100);
digitalWrite(pin,LOW);
delay(20-(Pulse/1000));
irrecv.enableIRIn();
pinMode(pwm_1,OUTPUT);
pinMode(dir_1,OUTPUT);
pinMode(pwm_2,OUTPUT);
pinMode(dir_2,OUTPUT);
pinMode( triggerPort, OUTPUT );
pinMode( echoPort, INPUT );
pinMode( triggerPort1, OUTPUT );
pinMode( echoPort1, INPUT );
pinMode( triggerPort2, OUTPUT );
pinMode( echoPort2, INPUT );
Serial.begin( 9600 );
Serial.println( "Sensore ultrasuoni: ");
void loop(){
//porta bassa l'uscita del trigger
digitalWrite( triggerPort, LOW );
//invia un impulso di 10microsec su trigger
digitalWrite( triggerPort, HIGH );
delayMicroseconds( 10 );
long duration = pulseIn( echoPort, HIGH );
long r = 0.034 * duration / 2;
Serial.print( "durata: " );
Serial.print( duration );
Serial.print( " , " );
Serial.print( "distanza: " );
//dopo 38ms è fuori dalla portata del sensore
if( duration > 38000 ) Serial.println( "fuori portata");
else { Serial.print( r ); Serial.println( "cm" );}
//secondosensore
digitalWrite( triggerPort1, LOW );
digitalWrite( triggerPort1, HIGH );
long duration1 = pulseIn( echoPort1, HIGH );
long r1 = 0.034 * duration1 / 2;
Serial.print( "durata1: " );
Serial.print( duration1 );
Serial.print( "distanza1: " );
if( duration1 > 38000 ) Serial.println( "fuori portata1");
else { Serial.print( r1 ); Serial.println( "cm1" );}
//sensore3
digitalWrite( triggerPort2, LOW );
digitalWrite( triggerPort2, HIGH );
long duration2 = pulseIn( echoPort2, HIGH );
long r2 = 0.034 * duration2 / 2;
Serial.print( "durata2: " );
Serial.print( duration2 );
Serial.print( "distanza2: " );
if( duration2 > 38000 ) Serial.println( "fuori portata");
else { Serial.print( r2 ); Serial.println( "cm" );}
if (irrecv.decode(&results)) // have we received an IR signal?
Serial.println(results.value, HEX); // display it on serial monitor in hexadecimal
irrecv.resume();// receive the next value
if ( results.value == 0x20DF02FD || results.value == 0x10406 ){ //ruota motore dc a destra
avanti();
if ( results.value == 0x20DF22DD || results.value == 0x10406 ){ //ruota motore dc a destra
STOP();
if ( results.value == 0x20DF609F || results.value == 0x10406 ){ //ruota motore dc a destra
destra();
if ( results.value == 0x20DF827D || results.value == 0x10406 ){ //ruota motore dc a destra
INDIETRO();
if ( results.value == 0x20DFE01F || results.value == 0x10406 ){ //ruota motore dc a destra
SINISTRA();
if ( results.value == 0x20DF7887 || results.value == 0x10406 ){ //ruota motore dc a destra
auto1();
if ( results.value == 0x20DF8877 || results.value == 0x10406 ){ //taglia
cutON();
void cutON()
digitalWrite(pin, HIGH);
delayMicroseconds(1500);
digitalWrite(pin, LOW);
delay(20-(1250/1000));
void avanti()
digitalWrite(dir_1,LOW);
digitalWrite(dir_2,HIGH);
analogWrite(pwm_1,speed);
analogWrite(pwm_2,speed);
void STOP()
digitalWrite(pwm_1,0);
digitalWrite(pwm_2,0);
void SINISTRA()
digitalWrite(dir_1,HIGH);
void destra()
digitalWrite(dir_2,LOW);
void INDIETRO()
void auto1(){
//secondosensore
//sensore3
if (r2<50){
if (r1<30){
else if (r1<50){
if (r2<30){
else{
else if (r<30){
else {
