ur code look so simple, code from this forum.
Try it
//clock SDA to analog pin 4 SCL to analog pin 5
#define DEBUG //compile serial monitor clock display
#define SETCLOCK //compile clock setup code
#include "Wire.h"
#define DS1307_I2C_ADDRESS 0x68 //seven bit address
#define MAXLINE 10
#define Mode12 1
#define Mode24 0
#define AM 0
#define PM 1
int led= 8;
int tnow,ton=8,toff=15;
static char *dayname[] =
{ "Sun",
"Mon",
"Tue",
"Wed",
"Thu",
"Fri",
"Sat"
Wire.begin();
pinMode(led,OUTPUT);
#ifdef SETCLOCK
char ans[1];
int serbytes=0;
Serial.println("Enter 'y' to set clock");
serbytes = getSerStrWait(ans, 1, 10);
if (strcmp(ans, "y") == 0) {
setClock();
#endif
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year, ampm;
getClock(&second, &minute, &hour, &dayOfWeek, &dayOfMonth, &month, &year, &m);
#ifdef DEBUGa
leadzero(hour);
Serial.print(hour, DEC);
Serial.print(":");
leadzero(minute);
Serial.print(minute, DEC);
Serial.print(":");
leadzero(second);
Serial.print(second, DEC);
if (ampm != ' ') { //not space
Serial.print(" ");
Serial.print(ampm);
Serial.print("M");
Serial.print(" ");
leadzero(month);
Serial.print(month, DEC);
Serial.print("/");
leadzero(dayOfMonth);
Serial.print(dayOfMonth, DEC);
Serial.print("/");
leadzero(year);
Serial.print(year, DEC);
Serial.print(" ");
Serial.println(dayname[dayOfWeek-1]);
#endif
tnow= hour;
if ((tnow>=ton)&&(tnow<toff))
digitalWrite(led, HIGH);
digitalWrite(led, LOW);
void leadzero(byte val) {
if (val < 10) {
Serial.print("0");
#ifdef SETCLOCK
void setClock() {
//prompt for time settings
byte second, minute, hour, dayOfWeek, dayOfMonth, month, year;
byte mode = 0;
byte ampm = 0;
char ans[1];
char dig2[3];
int serbytes=0;
Serial.println("Enter 2 dig year");
serbytes = getSerStr(dig2, 2);
year = atoi(dig2);
Serial.println("Enter 2 dig month");
month = atoi(dig2);
Serial.println("Enter 2 dig day of month (1-31)");
dayOfMonth = atoi(dig2);
Serial.println("Enter day of week where 1=SUN 2=MON 3=TUE 4=WED 5=THU 6=FRI 7=SAT");
serbytes = getSerStr(dig2, 1);
dayOfWeek = atoi(dig2);
Serial.println("Enter clock mode - 12 or 24");
if (strcmp(dig2, "12") == 0) {
mode = Mode12;
Serial.println("Enter 'a' or 'p' for AM or PM");
serbytes = getSerStr(ans, 1);
if (strcmp(ans, "p") == 0) {
ampm = PM;
Serial.print("Enter 2 dig hour ");
if (mode == Mode12) {
Serial.println("(1-12)");
}else{
Serial.println("(0-23)");
hour = decToBcd(atoi(dig2));
Serial.println("Enter 2 dig minute");
minute = atoi(dig2);
second = 0;
bitSet(hour, 6);
if (ampm == PM) {
bitSet(hour, 5);
Wire.beginTransmission(DS1307_I2C_ADDRESS);
Wire.write(0);
Wire.write(decToBcd(second)); // 0 to bit 7 starts the clock
Wire.write(decToBcd(minute));
Wire.write(hour); //already formatted with bits 6 and 5
Wire.write(decToBcd(dayOfWeek));
Wire.write(decToBcd(dayOfMonth));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.endTransmission();
#endif
// Gets the date and time from the ds1307
void getClock(byte *second,
byte *minute,
byte *hour,
byte *dayOfWeek,
byte *dayOfMonth,
byte *month,
byte *year,
byte *ampm)
byte work;
byte mode; //12 or 24 hour
byte ap_ind; //am or pm indicator
// Reset the register pointer
Wire.write(0);
Wire.requestFrom(DS1307_I2C_ADDRESS, 7);
// A few of these need masks because certain bits are control bits
*second = bcdToDec(Wire.read() & 0x7f); //mask CH bit (bit 7)
*minute = bcdToDec(Wire.read());
// *hour = bcdToDec(Wire.read());
work = Wire.read(); // get hour byte
mode = bitRead(work, 6); // if bit 6 set, running 12 hour mode
ap_ind = bitRead(work, 5); // if bit 5 set, time is PM
*hour = bcdToDec(work & 0x1f); // mask bits 5 thru 7 for 12 hour clock
if (ap_ind == PM) {
*ampm = 'P';
}else{
*ampm = 'A';
}else{
*hour = bcdToDec(work & 0x3f); // mask bits 6 and 7 for 24 hour clock
*ampm = ' ';
*dayOfWeek = bcdToDec(Wire.read());
*dayOfMonth = bcdToDec(Wire.read());
*month = bcdToDec(Wire.read());
*year = bcdToDec(Wire.read());
#ifdef SETCLOCK
int getSerStr(char line[], int lim) {
int bytesread=0;
int val=0;
Serial.flush();
while(bytesread<lim) {
if( Serial.available() > 0) {
val = Serial.read();
if((val == 10) || (val == 13) || (val == '*')) {
break; // stop reading
line[bytesread] = val; // add the digit
bytesread++; // ready to read next character
line[bytesread] = '\0'; //terminate string
return(bytesread);
int getSerStrWait(char line[], int lim, int waitsecs) {
int bytesread=0;
int val=0;
unsigned long waitms = 1000 * waitsecs;
unsigned long start = millis();
Serial.flush();
if (millis() - start > waitms) {
Serial.flush();
line[0] = '\0';
return(0);
return(bytesread);
#endif
//BCD to decimal conversion: decVal =(bcdVal.NIB1 * 10) + bcdVal.NIB0
//decimal to BCD conversion: bcdVal = (decVal / 10 <<4) + bcdVal // 10
// Convert normal decimal numbers to binary coded decimal
byte decToBcd(byte val)
return ( (val/10*16) + (val%10) );
// Convert binary coded decimal to normal decimal numbers
byte bcdToDec(byte val)
return ( (val/16*10) + (val%16) );
// Stops the DS1307, but it has the side effect of setting seconds to 0
// Probably only want to use this for testing
/*void stopDs1307()
Wire.write(0);
Wire.write(0x80);
