problem with running libraries, mac osx , uno
Hey
I have tried to find the solution but I can´t figure out how to fix it.
The problem is I can´t run the time och temp libraries on arduino v.22
I´m able to se them under examples but when i run the verify on time library i get the error
Error code
TimeAlarmExample.cpp:13:18: error: Time.h: No such file or directory
TimeAlarmExample.cpp:14:24: error: TimeAlarms.h: No such file or directory
TimeAlarmExample.cpp: In function 'void setup()':
TimeAlarmExample:24: error: 'setTime' was not declared in this scope
TimeAlarmExample:26: error: 'Alarm' was not declared in this scope
TimeAlarmExample.cpp: In function 'void loop()':
TimeAlarmExample:56: error: 'Alarm' was not declared in this scope
TimeAlarmExample.cpp: In function 'void digitalClockDisplay()':
TimeAlarmExample:62: error: 'hour' was not declared in this scope
TimeAlarmExample:63: error: 'minute' was not declared in this scope
TimeAlarmExample:64: error: 'second' was not declared in this scope
I have installed the libraries under document/arduino/libraries/
I have even tried installing them under arduino package contents
contents/Resources/Java/libraries/
I have restart the program and even the mac but it still dosen´t work.
macbook pro MAC osx
Arduino v.22
Arduino UNO
does any one know what the problem could be?
You don’t need to put them in the package contents.
Make sure you are putting them in /Users//Documents/Arduino/libraries
Make sure the actual libraries are nested in another folder. If you are using the same library I am, in the libraries folder I have “OneWire, Time, and TimeAlarms” all listed. They aren’t nested inside of another folder.
Just figured out the problem, you are right it was under time/time which was the problem and the temp library was missing the OneWire library
Thanks for the help anyway
