Dear all.
I am having some trouble with my SD-card and the SPI bus. I am using Arduino Uno R3 with the MP3 Player Shield from SparkFun. SparkFun MP3 Player Shield - DEV-12660 - SparkFun Electronics I am trying to use it in conjunction with a Real-Time Clock, but for now, the question is regarding the SPI bus and SD-card.
I am using the SD library included with the Arduino, and I am able to access the SD card fine, as long as nothing else access the SPI bus before it. See the following code, which is a slightly modified version of the "Datalogger" example sketch.
#include <SPI.h>
#include <RTC.h>
SD card datalogger
This example shows how to log data from three analog sensors
to an SD card using the SD library.
The circuit:
* analog sensors on analog ins 0, 1, and 2
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created 24 Nov 2010
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SD.h>
// On the Ethernet Shield, CS is pin 4. Note that even if it's not
// used as the CS pin, the hardware CS pin (10 on most Arduino boards,
// 53 on the Mega) must be left as an output or the SD library
// functions will not work.
const int chipSelect = 9;
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
pinMode(15, OUTPUT);
digitalWrite(15, HIGH);
pinMode(16, OUTPUT);
digitalWrite(16, HIGH);
pinMode(10, OUTPUT);
digitalWrite(10, HIGH);
pinMode(9, OUTPUT);
digitalWrite(9, HIGH);
pinMode(6, OUTPUT);
digitalWrite(6, HIGH);
SPI.begin();
RTC.setup();
Serial.print("Initializing SD card...");
// make sure that the default chip select pin is set to
// output, even if you don't use it:
// see if the card is present and can be initialized:
if (!SD.begin(chipSelect)) {
Serial.println("Card failed, or not present");
// don't do anything more:
return;
Serial.println("card initialized.");
RTC.setTime(00, 44, 10, 17, 7, 13);
Serial.print(RTC.getWeekday());
Serial.print(" ");
Serial.print(RTC.getDay());
Serial.print("/");
Serial.print(RTC.getMonth());
Serial.print("/");
Serial.print(RTC.getYear());
Serial.print(" ");
Serial.print(RTC.getHour());
Serial.print(":");
Serial.print(RTC.getMinute());
Serial.print(":");
Serial.println(RTC.getSecond());
// make a string for assembling the data to log:
String dataString = "";
// read three sensors and append to the string:
for (int analogPin = 0; analogPin < 3; analogPin++) {
int sensor = analogRead(analogPin);
dataString += String(sensor);
if (analogPin < 2) {
dataString += ",";
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
File dataFile = SD.open("datalog.txt", FILE_WRITE);
// if the file is available, write to it:
if (dataFile) {
dataFile.println(dataString);
dataFile.close();
// print to the serial port too:
Serial.println(dataString);
// if the file isn't open, pop up an error:
else {
Serial.println("error opening datalog.txt");
Serial.print("PIN 6: ");
Serial.println(digitalRead(6));
Serial.print("PIN 9: ");
Serial.println(digitalRead(9));
Serial.print("PIN 10: ");
Serial.println(digitalRead(10));
SPI.setClockDivider(SPI_CLOCK_DIV4);
SPI.setDataMode(SPI_MODE1);
//digitalWrite(10, LOW);
//SPI.transfer(0x05);
//int result = SPI.transfer(0x00);
//digitalWrite(10, HIGH);
/*SPI.setClockDivider(SPI_CLOCK_DIV16);
SPI.setDataMode(SPI_MODE0);
This code works perfectly and outputs the following result:
RTC setup complete
Initializing SD card...card initialized.
42,1018,1018
42,1018,1018
42,1018,1018
42,1018,1018
42,1018,1018
42,1018,1017
42,1018,1017
41,1018,1018
42,1018,1018
42,1018,1018
I then alter the code slightly, adding a term SPI.transfer(0x00); at the end of the file. The long term goal is to communicate with the RTC as mentioned, but for now I am troubleshooting. The foll code is then:
#include <SPI.h>
#include <RTC.h>
SD card datalogger
The circuit:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created 24 Nov 2010
modified 9 Apr 2012
by Tom Igoe
#include <SD.h>
while (!Serial) {
pinMode(9, OUTPUT);
pinMode(6, OUTPUT);
SPI.begin();
RTC.setup();
return;
Serial.print(" ");
Serial.print("/");
Serial.print("/");
Serial.print(" ");
Serial.print(":");
Serial.print(":");
dataString += ",";
if (dataFile) {
dataFile.close();
else {
The only change is the addition of a SPI.transfer(), and the output is this:
RTC setup complete
42,1018,1018
The code runs fine the first time in the loop, but after having the SPI.transfer called, it refuses to operate ever again. I have checked all the SC pins, and they are all high when this is called, so I did not think it would affect anything. I am utterly baffled as to why this happens, and would greatly appreciate some input.
Thank you all very much!
