Problem with SD library
Hello everybody,
After having lasted many hours on my application, I think that the problem comes from the SD library. That is :
if I first want to list files then read/write files, that’s OK. But, if I first read/write files and after I want to list files, the second listing is wrong (missing files).
To show you the problem, I have modified the example “listfile” in which I have added a write file between two listing. The first listing is correct, the write is correct but the second listing is wrong (missing files).
For the test, I have a Mega2560 board with TouchScreen 320 x 240 that supports the SD card reader. I use a
2 Mb SD card on which I have some files at the root…
Did you meet this problem ? Can you test the included sketch and tell me what are the results you obtain.
NOTE, be carefull to the right value to set in : “SD.begin(xx)” ( xx = 53 is for my case)
Thank you for your help.
Pierre
  SD card basic file example
 This example shows how to create and destroy an SD card file
 The circuit:
 * SD card attached to SPI bus as follows:
 ** MOSI - pin 11
 ** MISO - pin 12
 ** CLK - pin 13
 ** CS - pin 4
 created   Nov 2010
 by David A. Mellis
 modified 9 Apr 2012
 by Tom Igoe
 This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
File root;
  while (!Serial) {
    ; // wait for serial port to connect. Needed for Leonardo only
  Serial.print("Initializing SD card...");
  // On the Ethernet Shield, CS is pin 4. It's set as an output by default.
  // Note that even if it's not used as the CS pin, the hardware SS pin
  // (10 on most Arduino boards, 53 on the Mega) must be left as an output
  // or the SD library functions will not work.
  pinMode(10, OUTPUT);
  if (!SD.begin(53)) {
    Serial.println("initialization failed!");
    return;
  Serial.println("initialization done.");
  root = SD.open("/");
  printDirectory(root, 0);
  Serial.println("done!");
  ecritFichier();
  // nothing happens after setup finishes.
void printDirectory(File dir, int numTabs) {
  while(true) {
    File entry =  dir.openNextFile();
    if (! entry) {
      // no more files
      Serial.println("**nomorefiles**");
    for (uint8_t i=0; i<numTabs; i++) {
      Serial.print('\t');
    Serial.print(entry.name());
    if (entry.isDirectory()) {
      Serial.println("/");
      printDirectory(entry, numTabs+1);
    else {
      // files have sizes, directories do not
      Serial.print("\t\t");
      Serial.println(entry.size(), DEC);
    entry.close();
void ecritFichier() {
  myFile = SD.open("test.txt", FILE_WRITE);
  // if the file opened okay, write to it:
  if (myFile) {
    Serial.print("Writing to test.txt...");
    myFile.println("testing 1, 2, 3.");
    Serial.println("testing 1, 2, 3.");
    // close the file:
    myFile.close();
You should post a link to the Touchscreen hardware and a description on how it is connected to the Mega.
You should have posted this in the "Storage" section of the forum.
SurferTim,
my set is as follow : http://www.ebay.com/itm/SainSmart-Mega2560-3-2-TFT-LCD-Shield-Touch-Screen-SD-Reader-for-Arduino-2560-/271019848784
Sorry, I thought that troubleshooting was the right section. How to move to the right sction ?
Sincerely.
Pierre
I'll see if I can get a moderator to move your thread to the Storage section. You will probably get more help there than here.
I don't know how the SD library handles more than one file open at a time. You seem to have two open at once.
Thank you SurferTim,
In the SD.h, it said that “only one file can be open at a time.” It’s what I pay attention to do. But about Handle, nothing is said. So how to release a Handle ?
Pierre
root in your setup is a file handle.
root.close()
You also try to open a file in ecritFichier(); It's file handle is myFile.
You are right.
In the sketch, I have deleted "myFile" and replaced it by "root", so I have just one handle.
I also have added "root.close();" after the first call to printDirectory(root, 0);"
the problem is always the same ???
Pierre
