problem with sdcard and sram 23LC1024
Connecting sd card (http://www.hobbytronics.co.uk/microsd-card-regulated-v2) and sram 23LC1024 so SPI data written to ram are wrong, (I write all the data in RAM are wrong)
I have read many posts in the forum, many people have this problem, but I could not find the solution to the problem of multiple spi
someone has an idea?
Post your code. Explain how you know that the data written is wrong.
thanks for the reply.
you describe the problem:
Sending data with Bluetooth Arduino mini to correctly receive the data, writing the data received in memory, while the readDataFromRam function () read from memory the received data and print data.
For example, sending the characters:
x
y
z
w
the data read from the memory does not match the characters.
I think it's a problem because I use two SPI.
configuration that I use:
- Arduino Mini V05
- Sram 23LC1024 (microchip), with this configuration
http://ucexperiment.wordpress.com/2013/02/26/more-memory-arduino-and-23lc1024/
(my SS pin is 10)
- Micro sd
(my SS is 9)
Below is the code for that use.
  does not work with this code
If I remove the micro sd, then it works
code
#include <avr/pgmspace.h>
#include  <SPI.h>
int printer_RX_Pin = 6;
int printer_TX_Pin = 7;
const int rxPin = 4;
const int txPin = 5;
const int atPin = 3;
const int bSize = 80;
int ByteCount;
char Buffer[bSize];
 //SRAM opcodes
#define RDSR        5
#define WRSR        1
#define READ        3
#define WRITE       2
# define DATAOUT 11 / / MOSI
# define DATAIN 12 / / MISO
# define SPICLOCK 13 / / SCK
uint32_t addressIncrementale=0;
const long timeout = 10000;  //abbassare tempo di non ricezione
int finished=0;
SoftwareSerial bluetooth(rxPin, txPin);  //IDE >= 1.0
    initParam();
    bluetooth.begin(9600);
    startOperations();
void initParam()
    initParam_zero();
    pinMode(10, OUTPUT);
    pinMode(9, OUTPUT);
    pinMode(8, INPUT_PULLUP);
    digitalWrite(9, HIGH);
    digitalWrite(8, HIGH);
    digitalWrite(10, HIGH);
    SPI.begin();
    SPI.setClockDivider(4);
    digitalWrite(10,LOW);
 void initParam_zero()
   pinMode ( SCK , OUTPUT ) ;
   pinMode ( MOSI , OUTPUT ) ;
   digitalWrite ( SCK , LOW ) ;
   digitalWrite ( MOSI , LOW ) ;
void startOperations()
  int  val=digitalRead(8);
  (if you pressed the button calls procedure ...)
  startReceivingData();
  if(finished==1)
    readDataFromRam();
void startReceivingData()
     while(1)
        readByte();
        while (!bluetooth.available())
	 5 seconds after that I do not get out of the while loop
         and sets flag finished=1
void readByte()
   ByteCount = -1;
   ByteCount =  bluetooth.readBytes(Buffer,bSize-1);
   if (ByteCount  > 0)
     for( int k=0;k < ByteCount; k++)
       Spi23LC1024Write8(addressIncrementale, (uint8_t) Buffer[k]);
       addressIncrementale++;
  memset(Buffer, '\0', sizeof(Buffer));   // Clear contents of Buffer
void readDataFromRam()
  for ( uint32_t y=0;y< addressIncrementale;y++)
      uint8_t  data= (uint8_t )Spi23LC1024Read8(y);
      Serial.print((char)data);
 //Byte transfer functions
uint8_t Spi23LC1024Read8(uint32_t address) {
  uint8_t read_byte;
  PORTB &= ~(1<<PORTB2);        //set SPI_SS low
  SPI.transfer(READ);
  SPI.transfer((uint8_t)(address >> 16) & 0xff);
  SPI.transfer((uint8_t)(address >> 8) & 0xff);
  SPI.transfer((uint8_t)address);
  read_byte = SPI.transfer(0x00);
  PORTB |= (1<<PORTB2);         //set SPI_SS high
  return read_byte;
void Spi23LC1024Write8(uint32_t address, uint8_t data_byte) {
  SPI.transfer(WRITE);
  SPI.transfer(data_byte);
If you can't be bothered to post code correctly, I can't be bothered to read it.
hello,
I’m sorry but I have not seen that in my post were present smile instead of the number 8.
I am attaching the code below.
Yesterday I made other tests with Arduino one works properly.
Arduino one works correctly without setting SPI.setClockDivider,
while with Arduino mini I’m forced to set SPI.setClockDivider (4) otherwise it does not work.
#include <SPI.h>
int ByteCount;
char Buffer[bSize];
//SRAM opcodes
#define RDSR 5
#define WRSR 1
#define READ 3
#define WRITE 2
int finished=0;
initParam();
startOperations();
void initParam()
initParam_zero();
pinMode(9, OUTPUT);
SPI.begin();
int val_8=8;
int val=digitalRead(val_8);
if (digitalRead(val_8)==0)
procedurePrint();
if(finished==1)
readDataFromRam();
int notReady=0;
while(1)
readByte();
notReady++;
if (notReady==10000)
finished=1;
void readByte()
ByteCount = -1;
if (ByteCount > 0)
memset(Buffer, ‘\0’, sizeof(Buffer)); // Clear contents of Buffer
uint8_t read_byte;
SPI.transfer(READ);
SPI.transfer((uint8_t)(address >> val_8) & 0xff);
return read_byte;
Still incorrectly. Modify your post. Select all the code. Select the # button above the row of smiley faces. Save the changes. See the pretty code box?
pafra:
hello,
#include <SPI.h>
int ByteCount;
char Buffer[bSize];
//SRAM opcodes
#define RDSR 5
#define WRSR 1
#define READ 3
#define WRITE 2
int finished=0;
initParam();
startOperations();
void initParam()
initParam_zero();
pinMode(9, OUTPUT);
SPI.begin();
int val_8=8;
procedurePrint();
if(finished==1)
readDataFromRam();
int notReady=0;
while(1)
readByte();
notReady++;
finished=1;
void readByte()
ByteCount = -1;
if (ByteCount > 0)
uint8_t read_byte;
SPI.transfer(READ);
return read_byte;
I have attached the file, to make sure you have the correct font formatting…
thanks
test_arduino_mini.ini (3.17 KB)
