Problem with SE8R01
Hello. I'm trying to connect the SE8R01 module using this forum, but they don't transmit/receive data.
This is what I'm getting.
status = FF
*******************Radio starting*****************
*******************RX mode************************
status = E
*******************TX****************************
E
1E
1E
1E
I've checked all connections and they're is ok.
Did you read answer #4? The poster got exactly the same output. It's probably time to re-check your connections once again. If you still think you wired correctly, post a wiring diagram and some sharp photos where all wiring is visible.
