I'm a bit of a beginner and I have tried many of the solutions posted on other threads about this but none have worked so I've come to ask for help!
So I'm making a remote controlled robot car that communicates with the remote using HC-05 bluetooth modules. I have an x-y joystick, a pushbutton, and a potentiometer on the remote that sends four bytes of data to the car. Here's the code:
unsigned int xAxis, yAxis, button;
int buttonPin = 2;
int potPin = A4;
unsigned int potValue;
pinMode(A0, INPUT);
pinMode(A1, INPUT);
pinMode(buttonPin, INPUT_PULLUP);
Serial.begin(38400);
xAxis = analogRead(A0)/4;
yAxis = analogRead(A1)/4;
button = digitalRead(buttonPin);
potValue = analogRead(potPin)/4;
byte buf[4] = {xAxis , yAxis , button, potValue};
Serial.write(buf, sizeof(buf));
delay(20);
On the receiving end, I'm trying to assign those four bytes to the proper variables. The xAxis and yAxis variables control the motion of the car, the pushbutton toggles the max speed of the motor between 'slow' and 'fast', and the potValue turns a servo. Here's the part of the code:
while (Serial.available() >= 4) {
for (int i; i < 4; i++) {
buf[i] = Serial.read();
delay(5);
xAxis = buf[0] * 4;
yAxis = 1023 - (buf[1] * 4);
pos = map(buf[3], 0, 255, 8, 180);
buttonState = buf[2];
delay(15);
Serial.println(pos);
Serial.println(xAxis);
Serial.println(yAxis);
Serial.println(buttonState);
Serial.println("");
My problem is that the variables seem to get assigned randomly and it changes every time I reset either of the boards. What am I doing wrong here? From my limited knowledge, I would expect the four bytes to be sent to the buffer sequentially and read in the proper order, but it's not doing that. Is there a better, more proper way to do this? Any help would be appreciated! Thanks
