Problem with sending data from Arduino through XBee in API mode
Hello,
I want to make a network where coordinator is collecting data from 3 end devices. End devices are getting data from Arduino through serial port. I want to use them in API2 mode but then i don’t receive anything on my coordinator. When I’m using AT mode i receive data correctly so i thought there is something wrong with the packets i send. However i was using XBee library for Arduino, then just for test i tried to send hardcoded frame generated by X-CTU - and nothing is working. Could you give me any idea what the problem may be?
Here is my test code:
byte packet[] = {0x7E, 0x00, 0x07, 0x83, 0xFF, 0xFC, 0x00, 0x01, 0xFF, 0xFF, 0x82};
Serial.write(packet, sizeof(packet));
Here is example with XBee.h library (it’s sending value from pin5):
#include <XBee.h>
XBee xbee = XBee();
uint8_t payload[] = { 0, 0 };
Tx16Request tx = Tx16Request(0x0001, payload, sizeof(payload));
int pin5 = 0;
  xbee.setSerial(Serial);
 if (millis() - start > 15000) {
      // break down 10-bit reading into two bytes and place in payload
      pin5 = analogRead(5);
      payload[0] = pin5 >> 8 & 0xff;
      payload[1] = pin5 & 0xff;
      xbee.send(tx);
