Problem with sending numbers via bluetooth
Hello,
I am making a project to control servo motors by bluetooth. So I'm using an Arduino UNO, a bluetooth HC-05 module and an application developed in the MIT app inventor. I have 3 servo motors, when sending values smaller than 127 it does okay, however for values greater than 128 on the serial monitor, it shows negative values. For example, when I send 135 it gets -121. In the MIT inventor app I am already sending the data with 2 Bytes and the variable that receives them is of type int. In the annex, I show the part of the blocks that I used in MIT.What do you suggest I do?
Image from Original Post so we don't have to download it. See this Image Guide
...R
It sounds as if you may be forcing a byte (unsigned) value into a char - which is a signed variable.
But as you have not posted your Arduino code that is just a wild guess.
Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
...R
#include<SoftwareSerial.h>
#include<Servo.h>
Servo myservo1;
Servo myservo2;
Servo myservo3;
int bluetoothTx = 10;
int bluetoothRx = 11;
int recebido = 0;
int num;
String device;
SoftwareSerial bluetooth(bluetoothTx, bluetoothRx);
myservo1.attach(3);
myservo2.attach(5);
myservo3.attach(6);
//Setup usb serial connection to computer
//Setup Bluetooth serial connection to android
bluetooth.begin(9600);
    while (bluetooth.available())       //Check if there is an available byte to read
    delay(10);                        //Delay added to make thing stable
    char c = bluetooth.read();       //Conduct a serial read
    device += c;                    //build the string.
    if (device.length() > 0)
    Serial.println(device);
   char motor = device[0];
   int angulo = device[2];
   Serial.print(" ");
   Serial.println(angulo);
   Serial.println(motor);
   if ( motor == 'a')
          Serial.print("angulo1");
          myservo1.write(angulo);
   if ( motor == 'b')
          Serial.print("angulo2");
          myservo2.write(angulo);
   if ( motor == 'c')
          Serial.print("angulo3");
          myservo3.write(angulo);
   device=""; //Reset the variable
You are not using the String object correctly, but Strings should not be used at all with Arduino, because they cause memory problems.
Study the link in reply#2.
