Problem with Serial.print formatting
I have written a bit of diagnostic code to check out some added hardware to my Arduino Uno. Having written some random data to the added hardware (memory), I read it back and compare it against what was written. However, the serial monitor "appears" to be adding a byte of FF for negative hex numbers. Here is a code snippet- Serial.print("Data compare error at location "); Serial.print(j*512+i,DEC); Serial.print(" Read data = "); sprintf(chMsg,"%02X",chDataR); Serial.print(chMsg); Serial.print("\t");
Serial.print(" Write data = "); sprintf(chMsg,"%02X",chDataW); Serial.print(chMsg); Serial.print(" \n");
and here is a bit of serial monitor output to show the problem (lines 6 and 7):-
------- End of block 44 --------- Time for 512 byte block = 6816 microseconds. (13 uSecs per byte.) ------- End of block 45 --------- Time for 512 byte block = 6816 microseconds. (13 uSecs per byte.) Data compare error at location 23890 Read data = 0A Write data = 45 Data compare error at location 23891 Read data = FFA1 Write data = 50 Data compare error at location 23892 Read data = 3E Write data = FF9F .....
Any ideas about why the serial monitor is introducing this "sign extension" ?? Many thanks !
Looks like you hit the nail on the head.
Please don't post snippets, and when you post code, please use code tags.
So what if I don't want sign extension ...... ?
If you don't want sign extension, don't use signed datatypes
AWOL: If you don't want sign extension, don't use signed datatypes
Ahhhh ! Had forgotten that char defaulted to signed ! (Distracted by the hex representation) All fixed ! Ta !
