Problem with Serial.println() and piezos
I have a problem with my circuit.
There are 6 piezos connected to an arduino Uno.
I send a message with Serial.printl() every time a piezo is knocked.
After a minute or two, several messages are being sent for only one knock.
What is the problem ?
Thank you in advance for your answer.
sketch.ino (436 Bytes)
Code from Original Post so others don't have to download it.
int analogPins[] = {0, 1, 2, 3 , 4, 5};
unsigned int lastTime[] = {0, 0, 0, 0, 0, 0};
int size = 6;
int i;
int val;
int piezoThreshold = 750;
int timeThreshold = 100;
  Serial.begin(250000);
  for (i = 0; i < size; i++)
    val = analogRead(i);
    if (val > piezoThreshold && (millis() - lastTime[i]) > timeThreshold)
      lastTime[i] = millis();
      Serial.print(i);
...R
Try separating your IFs like this (for clarity)
    if (millis() - lastTime[i]) > timeThreshold)
      lastTime[i] += timeThreshold;   // avoids accumulating small errors
      if (val > piezoThreshold )
        Serial.print(i);
...R
Something else I noticed - you should use 'unsigned long' for storing 'millis()' values, not 'unsigned int'.
Change this:-unsigned int lastTime[] = {0, 0, 0, 0, 0, 0};to this:-unsigned long lastTime[] = {0, 0, 0, 0, 0, 0};
