problem with serial
Slave: Arduino uno
Master: Arduino mega
code for uno:
#include <Servo.h>
String state;
String s1open = "s1 open";
String s1close = "s1 close";
Servo servo1;
 servo1.attach(9);
 while(Serial.available()==0) {}
  state = Serial.readStringUntil('\n');
if(state == s1open){
  servo1.write(180);
if(state == s1close){
  servo1.write(0);
code for Mega:
String state;
Serial1.begin(9600);
Serial.println("arduino is ready");
while(Serial.available()==0){}
state = Serial.readString();
Serial1.println(state);
Serial.println(state);
wireing: TX uno --> Rx1 mega
Rx uno --> Tx1 Mega
common ground
servo--> pin 9 uno
problem:
if i type in s1 close or s1 open in the serial or serial1 monitor of the Arduino mega, it doesnt work
if i type in s1 close or s1 open in the serial, but rewire the wires as:
Tx uno --> Rx0 mega
Rx uno --> Tx0 mega
it does work.
if i rewrite the code a little and i make the uno master and the mega slave it also works fine without rewireing. Can someone tell me where i went wrong making the uno slave and the mega master ? maybe a tip or a correction ?
Why don't you have readStringUntil() in the Mega?
I never use those functions anyway. Have a look at the examples in Serial Input Basics - simple reliable ways to receive data.
Also, while it is NOT the cause of your problem, it is not a good idea to use the String (capital S) class on an Arduino as it can cause memory corruption in the small memory on an Arduino. Just use cstrings - char arrays terminated with 0.
When you connect the Uno to Serial on the Mega it will receive the data direct from the Serial Monitor.
...R
so of i understand correctly, it is not possible to connenct the serial1/2/3 from the mega to the serial of the uno ?
i did some tests and found out that my uno is not recieving anything from my mega/serial 1
PlatoBE:
Sure you can. It's just that if you do that, you can't use the Uno serial to communicate with the USB host.
PlatoBE:
...which could mean a million things.
