Hi !
I need to use both "servo" and "virtualwire" libraries on the same arduino uno board.
I tried but it failed. There was the message "error vector 11" in the error box.
I searched on the net and it seems to be a timer problem (both libraries are using the same timer) and the only solutions I found was to use other libraries to control the servomotors (servotimer2 was often quoted)
But I don't know how to use those libraries and I can't find proper example.
Can someone please explain me this library or an other solution if it exist ?
Exactly the same as the regular Servo library.
I tried my former code with #include
I just replace "Servo myservo1" by :
ServoTimer2 myservo1; // create servo object to control a servo
ServoTimer2 myservo2; // create servo object to control a servo
sketch_apr27b:11: error: 'ServoTimer2' does not name a type
sketch_apr27b:12: error: 'ServoTimer2' does not name a type
It should be #include <ServoTimer2.h>
Also AFAIK you use servo.write(vvv) but the value vvv must be millisecs, not degrees.
...R
I wrote ServoTimer2.h on my code.
Alright thank you for the help.
But I still have a problem to declare my servo.
So, post your real code, and your error message(s).
You did download the ServoTimer2 library, didn't you?
Hello i have the same problem of compatibility and i may be stupid but i don't find where can i download ServoTimer2, can you help me ? ![]()
acharr:
You want I should google that for you? Well, OK.
https://www.google.com/search?q=servotimer2+download&ie=utf-8&oe=utf-8
I got my copy here
...R
Here is my code.
I corrected the mistakes but it still not compile ![]()
test_servotimer2_ino.ino (1.47 KB)
I downloaded the ServoTimer2 library from Robin2's link, unzipped it in the proper place, and copied your code into the IDE (started after installing the library). I got an "error", too:
Binary sketch size: 3,562 bytes (of a 30,720 byte maximum)
I have no idea how you would "fix" this.
I had to download the library again (the earlier copy got lost somewhere). I unzipped the download and copied the directory into the libraries directory of the Arduino IDE and your code in Reply #9 compiled without any problem.
...R
