Problem with servo.read() and array (Solved)
Hello to all.
Sorry if this has already been asked but I could not find it.
I have three servos that do the same after pushing the respective push button.
For that I am using arrays to code the servos and the push buttons.
I know that some are against it but since the servos are "inactive" for a while (minutes), I added the option "detach" to save energy.
For that, I thought in the following code:
  • read the last position written in the servo with servo.read()
  • check if the button is pressed
  • if the button is pressed, update position to new angle, else, position remain unchanged
  • compare the reading with the position
  • if it is the same, detach and update last position, else, attach, write and update last position
Here is the code:
#include <Servo.h>
const byte numservo = 3;
int buttonpin[numservo];
int buttonstate[numservo];
int buttonread[numservo];
int buttonprevious[numservo];
Servo servo[numservo];
int servopin[numservo];
int servopos[numservo];
int servostate[numservo];
int servoon = 100;
int servooff = 125;
int servoread[numservo];
unsigned long timecurr;
unsigned long timebutton[numservo];
unsigned long timedeb = 50;
unsigned long timeservo;
  Serial.println("Pimanel_Rolling_Car");
  for (int i = 0; i < numservo; i++) {
    buttonpin[i] = 2 + i;
    servopin[i] = 2 + numservo + i;
    pinMode(buttonpin[i], INPUT_PULLUP);
    servostate[i] = 1;
    servopos[i] = map(servostate[i], 0, 1, servoon, servooff);
    buttonprevious[i] = HIGH;
  timecurr = millis();
    buttonread[i] = digitalRead(buttonpin[i]);
    servoread[i]= servo[i].read(servopos[i]);
    if (buttonread[i] != buttonprevious[i]) {
      timebutton[i] = millis();
    if (timecurr - timebutton[i] > timedeb) {
      if (buttonread[i] != buttonstate[i]) {
        buttonstate[i] = buttonread[i];
        if (buttonstate[i] == LOW) {
          servostate[i] = !servostate[i];
          Serial.print("Servo ");
          Serial.print(i + 1);
          Serial.print(" is moving to ");
          Serial.println(servopos[i]);
    buttonprevious[i] = buttonread[i];
    if (servoread[i]==servopos[i] {
      servo[i].detach();
    else {
      servo[i].attach(servopin[i]);
      servo[i].write(servopos[i]);
I get the following error when validating the code:
Arduino: 1.8.12 (Windows 10), Placa:"Arduino Uno"
C:\***\Pimanel_Rolling_Car.ino: In function 'void loop()':
Pimanel_Rolling_Car:39:44: error: no matching function for call to 'Servo::read(int&)'
In file included from C:\***\Pimanel_Rolling_Car.ino:1:0:
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:113:7: note: candidate: int Servo::read()
   int read();                        // returns current pulse width as an angle between 0 and 180 degrees
C:\Program Files (x86)\Arduino\libraries\Servo\src/Servo.h:113:7: note:   candidate expects 0 arguments, 1 provided
exit status 1
What am I doing wrong?
Thanks in advance
Filipe Almeida
The servo read function doesn't take a parameter. Drop the
servopos[i]
From the line showing you an error.
Hi again
Ok. Now I see the "two" errors that I made.
First
servopos[i] instead of servopin[i]
and second
servo[i].read() do not require parameters at all
Thanks very much
Filipe Almeida
