Hi everyone! I recently purchased the large servo Feetech FT 5335M FB with feedback and I have been unable to make it work with an arduino and the simple code 'sweep' or any other code for that matter. I used an external 6 volt 4A battery, connecting grounds together, I checked the signal pin, everything was ok. What am I doing wrong? I didn't connect the feedback cable but it's not necessary, is it? It worked with a receiver and a transmitter, so it's not faulty. Any help would be appreciated, thanks.
Please post a schematic of your circuit
A photo of a hand drawn circuit is good enough
What exactly did you check at the signal pin ?
What exactly is your "6V 4A battery"? Batteries generally do not have current (A) specified.
Steve
Hi!
I've tried to attach a picture but I don't see a way to do it. Anyway, the schematic is fairly simple: we have the servo, whose signal cable is attached to the pin D7 in the Arduino, the + cable is connected to the positive in the external battery, which is a 6v and 4 AH battery, and the - cable of the servo is connected to the negative of the battery using a breadboard, and these negatives are connected to the GND in the Arduino. That's all I have, so any ideas?
Thanks a lot for your time!
https://images.app.goo.gl/GtN29vrm3zpiCPfX9
My setup is similar to this one, except the feedback cable coming from the servo (not on the picture) which isn't connected.
toptenacademy:
Do you mean a 6V 4Ah lead acid battery or something else?
Anyway your problem may well be the breadboard. Connecting the power to a high current-demand servo via a breadboard is not a good idea. Most breadboard connections are good for 200-300 mA at best.
Steve
There is also the potential problem that some breadboards have a gap in the centre of their power rails which has caught out people in the past
The spec I found said that the servo might draw bursts of 9A at 7.4V. I think this translates to 7.3A at 6V.
As long as the battery and Arduino share a Ground with the servo, it should work. The spec said that the signal works with both 5V or 3.3V.
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Then look down to item #7 about how to post your code.
What code are you using?
This is your servo with feedback?
Thanks.. Tom... ![]()
