Hello.
This is my first post here, so I will take this opportunity to say hello to everyone.
I'm trying to control a relay connected to the ESP32 dev board using MQTT trigger.
I modified this example to work for my needs: Link
Unfortunately there is a problem with my board and it only reconnect to the WIFI every other time. Apparently this is a known issue and as there is not fix yet I decide to use a workaround which I found here: Link
Now the fun begins.
Both codes work separately, but how to make them work together?
As the ESP32 is a dual core board I found this code, which allows to assign task to the core:
I tried to merge all 3 together, but i'm getting "'callback' was not declared in this scope" error.
My code:
#include <WiFi.h>
#include <PubSubClient.h>
#include <Wire.h>
const char* ssid = "XXX";
const char* password = "XXX";
// Add your MQTT Broker IP address
const char* mqtt_server = "XXX";
WiFiClient espClient;
PubSubClient client(espClient);
long lastMsg = 0;
char msg[50];
int value = 0;
// relay Pin
const int relayPin = 4;
TaskHandle_t Task1;
TaskHandle_t Task2;
client.setServer(mqtt_server, 1883);
client.setCallback(callback);
pinMode(relayPin, OUTPUT);
//create a task that will be executed in the myWiFiTask() function, with priority 1 and executed on core 0
xTaskCreatePinnedToCore(
myWiFiTask, /* Task function. */
"Task1", /* name of task. */
10000, /* Stack size of task */
NULL, /* parameter of the task */
1, /* priority of the task */
&Task1, /* Task handle to keep track of created task */
0); /* pin task to core 0 */
//create a task that will be executed in the MQTT() function, with priority 1 and executed on core 1
mqtt, /* Task function. */
"Task2", /* name of task. */
&Task2, /* Task handle to keep track of created task */
1); /* pin task to core 1 */
//myWiFiTask:
bool myWiFiFirstConnect = true;
void myWiFiTask(void *pvParameters) {
wl_status_t state;
while (true) {
state = WiFi.status();
if (state != WL_CONNECTED) { // We have no connection
if (state == WL_NO_SHIELD) { // WiFi.begin wasn't called yet
Serial.println("Connecting WiFi");
WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
} else if (state == WL_CONNECT_FAILED) { // WiFi.begin has failed (AUTH_FAIL)
Serial.println("Disconnecting WiFi");
WiFi.disconnect(true);
} else if (state == WL_DISCONNECTED) { // WiFi.disconnect was done or Router.WiFi got out of range
if (!myWiFiFirstConnect) { // Report only once
Serial.println("WiFi disconnected");
vTaskDelay (250); // Check again in about 250ms
} else { // We have connection
if (myWiFiFirstConnect) { // Report only once
myWiFiFirstConnect = false;
Serial.print("Connected to ");
Serial.println(ssid);
Serial.print("IP address: ");
Serial.println("");
vTaskDelay (5000); // Check again in about 5s
//MQTT
void mqtt( void * pvParameters ){
void callback(char* topic, byte* message, unsigned int length) {
Serial.print("Message arrived on topic: ");
Serial.print(topic);
Serial.print(". Message: ");
String messageTemp;
for (int i = 0; i < length; i++) {
Serial.print((char)message[i]);
messageTemp += (char)message[i];
// Feel free to add more if statements to control more GPIOs with MQTT
// If a message is received on the topic esp32/output, you check if the message is either "on" or "off".
// Changes the output state according to the message
if (String(topic) == "esp32/output") {
Serial.print("Changing output to ");
if(messageTemp == "on"){
Serial.println("Relay ON");
digitalWrite(relayPin, LOW); //pins on board seams to be working in "reverse"
else if(messageTemp == "off"){
Serial.println("Relay OFF");
digitalWrite(relayPin, HIGH); //pins on board seams to be working in "reverse"
void reconnect() {
// Loop until we're reconnected
while (!client.connected()) {
Serial.print("Attempting MQTT connection...");
// Attempt to connect
if (client.connect("ESP8266Client")) {
Serial.println("connected");
// Subscribe
client.subscribe("esp32/output");
Serial.print("failed, rc=");
Serial.print(client.state());
Serial.println(" try again in 5 seconds");
// Wait 5 seconds before retrying
delay(5000);
if (!client.connected()) {
reconnect();
client.loop();
long now = millis();
I think the problem is that "client.setCallback(callback);" cannot find "callback" function in my code as it is within another function. I'm new to the Arduino, and I cannot find any information online about how to solve this.
Please help me with fixing my sketch.
