Hi all. I have a problem with my shift registers (74hc 595) The "Hello World" sketch is working fine. But if I want to upload the "one by one" sketch nothing hapens. Sometimes the LEDs freeze.
So how have you wired it up? Link to the code you have used?
I have wired it up like in this tutorial: http://www.arduino.cc/en/Tutorial/ShiftOut
This one works: http://arduino.cc/en/Tutorial/ShftOut11
This one not: http://arduino.cc/en/Tutorial/ShftOut12
Got irritated of this line:
- 74HC595 shift register attached to pins 2, 3, and 4 of the Arduino,
Sorry!
Why did that line irritate you? If you mean that the compiler didn't like it, you need to post the EXACT error message.
This is one big comment section
Shift Register Example
for 74HC595 shift register
This sketch turns reads serial input and uses it to set the pins
of a 74HC595 shift register.
Hardware:
* 74HC595 shift register attached to pins 2, 3, and 4 of the Arduino,
as detailed below.
* LEDs attached to each of the outputs of the shift register
Created 22 May 2009
Created 23 Mar 2010
by Tom Igoe
If you are missing the start of the comment, the / * , then you may get odd errors.
Maybe it's that the comments say connected to pins 2, 3 & 4 but the sketch actually uses 8, 11 & 12.
MrMcChicken: I have wired it up like in this tutorial: http://www.arduino.cc/en/Tutorial/ShiftOut
The third sketch takes serial input and uses it to light the LEDs. Are you inputting anything into the serial console? If not it won't do much.
