hi
today i was trying to connect sim900 v1.4 gprs shield with arduino uno it was working fine then it just turned itself off i tried opening it again but it stays on for a while then again and when i put it on FXT it stays on until i close it so what can i do to fix this
thanks
the code:
/*Note: this code is a demo for how to using gprs shield to send sms message, dial a voice call and
send a http request to the website, upload data to pachube.com by TCP connection,
The microcontrollers Digital Pin 7 and hence allow unhindered
communication with GPRS Shield using SoftSerial Library.
IDE: Arduino 1.0 or later
Replace the following items in the code:
1.Phone number, don't forget add the country code
2.Replace the Access Point Name
3. Replace the Pachube API Key with your personal ones assigned
to your account at cosm.com
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial mySerial(7, 8);
mySerial.begin(19200); // the GPRS baud rate
//after start up the program, you can using terminal to connect the serial of gprs shield,
//if you input 't' in the terminal, the program will execute SendTextMessage(), it will show how to send a sms message,
//if input 'd' in the terminal, it will execute DialVoiceCall(), etc.
if (Serial.available())
switch(Serial.read())
case 't':
SendTextMessage();
case 'd':
DialVoiceCall();
case 'h':
SubmitHttpRequest();
case 's':
Send2Pachube();
if (mySerial.available())
Serial.write(mySerial.read());
///SendTextMessage()
///this function is to send a sms message
void SendTextMessage()
mySerial.print("AT+CMGF=1\r"); //Because we want to send the SMS in text mode
delay(100);
mySerial.println("AT + CMGS = "+973********"");//send sms message, be careful need to add a country code before the cellphone number
delay(100);
mySerial.println("A test message!");//the content of the message
delay(100);
mySerial.println((char)26);//the ASCII code of the ctrl+z is 26
delay(100);
mySerial.println();
///DialVoiceCall
///this function is to dial a voice call
void DialVoiceCall()
mySerial.println("ATD + +973*******;");//dial the number
delay(100);
mySerial.println();
///SubmitHttpRequest()
///this function is submit a http request
///attention:the time of delay is very important, it must be set enough
void SubmitHttpRequest()
mySerial.println("AT+CSQ");
delay(100);
ShowSerialData();// this code is to show the data from gprs shield, in order to easily see the process of how the gprs shield submit a http request, and the following is for this purpose too.
mySerial.println("AT+CGATT?");
delay(100);
ShowSerialData();
mySerial.println("AT+SAPBR=3,1,"CONTYPE","GPRS"");//setting the SAPBR, the connection type is using gprs
ShowSerialData();
mySerial.println("AT+SAPBR=3,1,"viva.bh","CMNET"");//setting the APN, the second need you fill in your local apn server
delay(4000);
ShowSerialData();
mySerial.println("AT+SAPBR=1,1");//setting the SAPBR, for detail you can refer to the AT command mamual
delay(2000);
ShowSerialData();
mySerial.println("AT+HTTPINIT"); //init the HTTP request
delay(2000);
ShowSerialData();
mySerial.println("AT+HTTPPARA="URL","www.google.com"");// setting the httppara, the second parameter is the website you want to access
ShowSerialData();
mySerial.println("AT+HTTPACTION=0");//submit the request
delay(10000);//the delay is very important, the delay time is base on the return from the website, if the return datas are very large, the time required longer.
//while(!mySerial.available());
ShowSerialData();
mySerial.println("AT+HTTPREAD");// read the data from the website you access
delay(300);
ShowSerialData();
mySerial.println("");
delay(100);
///send2Pachube()///
///this function is to send the sensor data to the pachube, you can see the new value in the pachube after execute this function///
void Send2Pachube()
ShowSerialData();
mySerial.println("AT+CSTT="CMNET"");//start task and setting the APN,
ShowSerialData();
mySerial.println("AT+CIICR");//bring up wireless connection
delay(3000);
ShowSerialData();
mySerial.println("AT+CIFSR");//get local IP adress
delay(2000);
ShowSerialData();
mySerial.println("AT+CIPSPRT=0");
delay(3000);
ShowSerialData();
mySerial.println("AT+CIPSTART="tcp","api.cosm.com","8081"");//start up the connection
delay(2000);
ShowSerialData();
mySerial.println("AT+CIPSEND");//begin send data to remote server
delay(4000);
ShowSerialData();
String humidity = "1031";//these 4 line code are imitate the real sensor data, because the demo did't add other sensor, so using 4 string variable to replace.
String moisture = "1242";//you can replace these four variable to the real sensor data in your project
String temperature = "30";//
String barometer = "60.56";//
mySerial.print("{"method": "put","resource": "/feeds/42742/","params"");//here is the feed you apply from pachube
ShowSerialData();
mySerial.print(": {},"headers": {"X-PachubeApiKey":");//in here, you should replace your pachubeapikey
ShowSerialData();
mySerial.print(" "_cXwr5LE8qW4a296O-cDwOUvfddFer5pGmaRigPsiO0");//pachubeapikey
ShowSerialData();
mySerial.print("jEB9OjK-W6vej56j9ItaSlIac-hgbQjxExuveD95yc8BttXc");//pachubeapikey
ShowSerialData();
mySerial.print("Z7_seZqLVjeCOmNbEXUva45t6FL8AxOcuNSsQS"},"body":");
ShowSerialData();
mySerial.print(" {"version": "1.0.0","datastreams": ");
ShowSerialData();
mySerial.println("[{"id": "01","current_value": "" + barometer + ""},");
ShowSerialData();
mySerial.println("{"id": "02","current_value": "" + humidity + ""},");
ShowSerialData();
mySerial.println("{"id": "03","current_value": "" + moisture + ""},");
ShowSerialData();
mySerial.println("{"id": "04","current_value": "" + temperature + ""}]},"token": "lee"}");
ShowSerialData();
mySerial.println((char)26);//sending
delay(5000);//waitting for reply, important! the time is base on the condition of internet
mySerial.println();
ShowSerialData();
mySerial.println("AT+CIPCLOSE");//close the connection
delay(100);
ShowSerialData();
void ShowSerialData()
while(mySerial.available()!=0)
