Hii everyone,
I am getting the following error while trying to get the GPS co ordinates using SIM908 GSM/GPRS/GPS quadband module.
GSM Shield testing.
DB:ELSE
DB:ELSE
DB:ELSE
status=IDLE
GSM Shield testing.
DB:ELSE
DB:ELSE
DB:ELSE
DB:DIFF RESP
DB:NO BR
DB:NO BR
DB:NO BR
DB:NO BR
DB:NO BR
DB:NO BR
DB:NO BR
status=IDLE
I'VE used the following code present in SIM908IDE library:
#include "SIM900.h"
#include <SoftwareSerial.h>
//#include "inetGSM.h"
//#include "sms.h"
//#include "call.h"
#include "gps.h"
//To change pins for Software Serial, use the two lines in GSM.cpp.
//GSM Shield for Arduino
//www.open-electronics.org
//this code is based on the example of Arduino Labs.
//Simple sketch to start a connection as client.
//InetGSM inet;
//CallGSM call;
//SMSGSM sms;
GPSGSM gps;
char lon[10];
char lat[10];
char alt[10];
char time[15];
char vel[10];
char msg1[5];
char msg2[5];
char stat;
char inSerial[20];
int i=0;
boolean started=false;
//Serial connection.
Serial.println("GSM Shield testing.");
//Start configuration of shield with baudrate.
//For http uses is raccomanded to use 4800 or slower.
if (gsm.begin(2400)){
Serial.println("\nstatus=READY");
gsm.forceON(); //To ensure that SIM908 is not only in charge mode
started=true;
else Serial.println("\nstatus=IDLE");
if(started){
//GPS attach
if (gps.attachGPS())
Serial.println("status=GPSON");
else Serial.println("status=ERROR");
delay(20000); //Time for fixing
stat=gps.getStat();
if(stat==1)
Serial.println("NOT FIXED");
else if(stat==0)
Serial.println("GPS OFF");
else if(stat==2)
Serial.println("2D FIXED");
else if(stat==3)
Serial.println("3D FIXED");
delay(5000);
//Get data from GPS
gps.getPar(lon,lat,alt,time,vel);
Serial.println(lon);
Serial.println(lat);
Serial.println(alt);
Serial.println(time);
Serial.println(vel);
//Read for new byte on serial hardware,
//and write them on NewSoftSerial.
serialhwread();
//Read for new byte on NewSoftSerial.
serialswread();
void serialhwread(){
i=0;
if (Serial.available() > 0){
while (Serial.available() > 0) {
inSerial*=(Serial.read());*
- delay(10);*
- i++; *
_ inSerial*='\0';_
_ if(!strcmp(inSerial,"/END")){_
Serial.println("");
_ inSerial[0]=0x1a;*
* inSerial[1]='\0';*
* gsm.SimpleWriteln(inSerial);*
* //Send a saved AT command using serial port.*
* if(!strcmp(inSerial,"TEST")){*
* Serial.println("BATTERY TEST 1");*
* gps.getBattInf(msg1,msg2);*
* Serial.println(msg1);*
* Serial.println(msg2);*
* Serial.println("BATTERY TEST 2");*
* gps.getBattTVol(msg1);*
* //Read last message saved.*
* if(!strcmp(inSerial,"MSG")){*
* Serial.println(lat);*
* else{*
* Serial.println(inSerial);*
* inSerial[0]='\0';*
void serialswread(){
* gsm.SimpleRead();*
please reply at the earliest.Thank you
