Problem with sizeof()
I've written a little timers utility as a function and declare it thus in the main programme :
extern byte timer(byte action, byte timer_no, unsigned long val);
enum timers { start_timer, menu_timer, mod_temps_timer, mod_times_timer, heating_timer, at_temp_timer,
              mugging_timer
const int maxtimers = sizeof(timers);
I got funny results, so then added
  Serial.print(maxtimers);
at the end of setup.
When ran in a nano it gave the value 2. Obviously it should be 7.
Any ideas?
Allan
It's an ugly idea, but if you're desperate, const int maxtimers = mugging_timer+1; I hope someone has a better idea...
Well, OK.
I can count, and could write maxtimers = 7 .
But I was hoping for something a bit more elegant.
Why should sizeof() get it wrong?
Allan
edit: It's actually ported from some stuff I wrote ages ago for a MSP430 target in the IAR IDE. Seemed OK there. /edit.
timers is a type now. It is the same size as an int.
Ah… so shouldn’t it then return 1? 7 is << 32567… Or does sizeof always presume bytes?
Any suggestions as to how should I do it?
thanks Allan
An enum is a compile-time abstraction that effectively does nothing but create a bunch of symbols. It does not HAVE a size, as it does not use any memory, and it's size certainly does not vary depending on how many members it has. Each symbol defined by the enum is an int, and sizeof(int) == 2. So, there is absolutely no "problem" with sizeof(), there is instead a problem with your expectation of what sizeof should do, which is quite different from what it is defined to do.
Regards,
Ray L.
allanhurst:
No, obviously you WANT it to be 7.
allanhurst:
The sizeof keyword always returns the number of bytes of a variable or data type.
I think your only option is to use something similar to what @aarg suggested:
or
const int maxtimers = mugging_timer - start_timer + 1;
or
enum timers { start_timer, menu_timer, mod_temps_timer, mod_times_timer, heating_timer, at_temp_timer, mugging_timer, LAST};
const int maxtimers = LAST;
Do you want to iterate with them?
              mugging_timer
const int timerList [] = { start_timer, menu_timer, mod_temps_timer, mod_times_timer, heating_timer, at_temp_timer,
              mugging_timer
const int maxtimers = sizeof(timerList[]);
I think...
Perhaps
const int maxtimers = sizeof(timerList) / sizeof(timerList[0]);
I think this is the best way to handle it:
              mugging_timer, maxtimers
it's less fragile than mugging_timer+1 because you just need to leave maxtimers as the last item if you add more.
Another trick I like to use with enum:
enum __attribute__((packed)) timers { start_timer, menu_timer, mod_temps_timer, mod_times_timer, heating_timer, at_temp_timer,
Makes them 1 byte instead of 2. I used to avoid using enum before discovering that.
