Hi all. I'm using a sketch
int Red, Green, Blue;
int RedPin = 10;
int GreenPin = 9;
int BluePin = 11;
Serial.begin(19200);
Red = 0;
Green = 0;
Blue = 0;
if (Serial.available()>=3) {
if(Serial.read() == 0xff){
Red = Serial.read();
Green = Serial.read();
Blue = Serial.read();
analogWrite (RedPin, Red);
analogWrite (GreenPin, Green);
analogWrite (BluePin, Blue);
I don't have any trouble running the code on Arduino Nano, Duemilanove, Uno R3, Pro mini everything works i have the exact output on the pin's selected I have even uploaded it to a atmega32 and it works but when i upload it to the mega, i don't get any output on the pins selected does not matter which pin's i select in the code there isn't anything please advice.
Where is the incomming serial data comming from ?
i.e from the PC or have you connected to the pins on the board because on ATMega32U4 boards the pins i.e 0 and 1 on the board are Serial1 not Serial
Apart from that, have you tried setting pinmode to output on the pins you want to use as outputs (though I doubt this is the problem)
hi i get the data from a program writen on java i do set the com port in java but the problem persist i will try with pin mode and write back
you are checking for available >= 3
and you read either 4 times or 1 time from serial so there is some thing wrong
try
if (Serial.available() >= 4) // <<<<<<<<<<
if (Serial.read() == 0xff)
in the line
i've tried with everything from 0 to 14.
