problem with SoftwareSerial
hello,
I am trying to a byte from arduino via HC-06 bluetooth module to my android phone.
bytes 0 to 127 work fine, i can read the corresponding ASCII value on my phone.
bytes 128 to 255 are not transmitted (or not received).
on the android side i used the app BlueTerm
is my arduino code correct ?
does SoftwareSerial only send 7bits ?
is the problem on the android side ?
thx in advance,
wowi
#include <SoftwareSerial.h>
SoftwareSerial BT(10, 11); // <-----this here defines TX/Rx ports---
uint8_t dat = 0; //single byte read
int i = 0;
int strStream[5] = {65, 97, 164, 178, 255};
    BT.begin(9600); // writing to HC-06 on D10(D11)
  while (i < 5) {
    dat = getNextByte(i);
    BT.write(dat);
    i++;
  i = 0;
uint8_t getNextByte(int i) {
  dat = strStream[i];
  return dat;
SoftwareSerial should send all 8 bits.
...R
  dat = strStream[i];
  return dat;
You assigned a 16 bit, signed value to an unsigned 8 bit variable, and expected the assignment to work perfectly. Time for a reality check.
Thanks Paul for catching that!
After hours of wasting energy looking in the wrong corners and even suspecting SoftwareSerial, I found that my incorrect bit masking on the Android side was actually the problem.
regards,
w
