Problem with SPI connection to TI ADS8681 programmable ADC
Hello Forum,
I’m trying to establish a SPI connetcion to the programmable analog digital converter TI ADS8681. In the future I wish to adress several
ADCs connected in a daisy chain (see ADC data sheet p.38). But as a first step I set up a connection to a single ADC, according to figure 71 (see ADC data sheet p.37). I want to connect a “aa battery” to the ADC to simulate an input. Then I hope to read the ADCs digital output via SPI. Finally the output shall be send to the serial port of a PC. My wiring is shown in the picture attached.
I wrote a code to cnfigure the ADC via its command registers and read the converted digital values.
But I have some trouble to reead those values via SPI.
Sadly I am new to arduino, microelectronics and C/C++ all together. Therefore I hope for a little help from this forum.
I’d like to thank for any help in advance.
// Read out a TI ADS8681 (ADC)
// Arduino MKR 1010 WIFI
// August 2020
// by SPL
#include <SPI.h>
// Arduino SPI Libray
// MISO
// SCK
// MOSI
const int CS = 7;
// set SPI Pins
// define Baud rate for serial data transfer
pinMode(MISO, INPUT);
pinMode(MOSI,OUTPUT);
pinMode(SCK, OUTPUT);
pinMode(CS, OUTPUT);
// set the SPI-Pin as an output/input:
digitalWrite(CS, HIGH);
// set CS to idle
writeRegister(0x08,0b00000000,0b00000000);
// define SPI Mode; address of the SDI_CTL_REG Register (hex) and define SPI Mode, ADC data sheet p. 51
// matches ARDUINO SPI Mode0
writeRegister(0x14,0b00000000,0b00000001);
// define Measurement Range 10,24 V, see p. 54 ADC data sheet;
read_adc_to_serial();
delay(5);
//read ADC and send result to serial
void read_adc_to_serial() {
byte package_read [4];
// define read variable
SPI.beginTransaction(SPISettings(1000000, MSBFIRST, SPI_MODE0));
// initialize SPI & SPI Settings defines speed Maximum in Hz, dataOrder and dataMode
// speed Maximum in Hz: 10 kHz, see ADW Data Sheet 6.6 (p. 11)
// dataOrder : MSBFIRST, see ADW Data Sheet 7.4.1.3 (p. 38)
// dataMode : ADC Data Sheet (p. 45);
digitalWrite(CS, LOW);
// CS low to start data transfer
//package_read[0] = shiftIn(MISO,SCK,MSBFIRST);
//package_read[1] = shiftIn(MISO,SCK,MSBFIRST);
//package_read[2] = shiftIn(MISO,SCK,MSBFIRST);
//package_read[3] = shiftIn(MISO,SCK,MSBFIRST);
// read shift register via “listening”
package_read[0] = SPI.transfer(0b00000000);
package_read[1] = SPI.transfer(0b00000000);
package_read[2] = SPI.transfer(0b00000000);
package_read[3] = SPI.transfer(0b00000000);
// read shift register via SPI library
// CS high to stop data transfer
SPI.endTransaction();
//end SPI
Serial.println(package_read[0], DEC);
Serial.println(package_read[1], DEC);
Serial.println(package_read[2], DEC);
Serial.println(package_read[3], DEC);
// print out data to serial;
delay(1);
// delay t_cycle-min for ADS8681, see p. 665 & 11 ADC data sheet
void writeRegister(byte thisRegister, byte thisValue1, byte thisValue2) {
// adopted from https://www.arduino.cc/en/Tutorial/BarometricPressureSensor
// see ADC programming p.43 data sheet
byte dataToSend = thisRegister;
SPI.beginTransaction(SPISettings(1000, MSBFIRST, SPI_MODE0));
// take the chip select low to select the device:
byte package1 [4] = {0b11010000,dataToSend,thisValue1,thisValue2};
// opcode, see p. 43 ADC data sheet
SPI.transfer(package1,4);
//Send register location & value
// set chip select high to de-select
//end SPI
I'm missing an SPI.begin() call in your setup() routine.
Please post a wiring diagram where pin numbers are readable (use a higher resolution).
The wiring ist updaten, thank you for the advice.
As I added the SPI.begin() behind "digitalWrite(CS, HIGH);// CS high to stop data transfer" I recieve the following signal on the serial monitor:
12:38:22.248 -> 0
12:38:22.248 -> 0
12:38:22.248 -> 0
12:38:22.248 -> 0
12:38:22.248 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 255
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.283 -> 0
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 0
12:38:22.317 -> 0
12:38:22.317 -> 0
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.317 -> 255
12:38:22.351 -> 0
12:38:22.351 -> 0
12:38:22.351 -> 0
12:38:22.351 -> 0
12:38:22.351 -> 255
12:38:22.351 -> 255
12:38:22.351 -> 255
12:38:22.351 -> 255
12:38:22.351 -> 255
12:38:22.351 -> 255
12:38:22.351 -> 255
12:38:22.351 -> 255
The signal varies and always contains zeros and blocks of 255.
If the battery is not connected to the ADC there are zeros in majority. If I connect it, there are 255 in majoty.
This is not hte kind of signal I was expecting, because there is no noise. In addition the zeros for the case of a connected battery are confusing.
The SPI speed is defined in chapter 6.8, you could go up to 67MHz. As you set it to 1MHz your comment is simply wrong.
You’re reading the voltage of a floating pin. What do you expect as the result? Attach a voltage (p.e. from a sensor) and read again.
I corrected the the comment, thanks.
For the case of a floating pin I get that. But for the case of a connected aa Battery (~1,5 V) and the
measurement range of ±10,24 V this seemed iritating for me. I adjusted the code of the read_adc_to_serial:
byte dataFrame [4];
// initialise
SPI.transfer(dataFrame,4);
// read shift register in variable ‘dataFrame’;
word package_read = dataFrame[0]<<8 | dataFrame[1];
Serial.println(package_read, DEC);
// convert and print out data to serial;
delay(1);
// delay t_cycle-min for ADS8681, p. 665 & 11 ADC data sheet
The ‘SPI.beginTransaction(SPISettings(100, MSBFIRST, SPI_MODE0));’ is now part of the setup and I convert the data output (p. 44 ADC Data Sheet) to a word. This leads to a constant Result of 65535, the maximum value of a word.
For the measurement range of ± 10,24 V and the battery voltage of ~1,5 V I would have expected another result. In addition there is no noise.
In addition I added a definition for the DATA_OUT_CTL_REG, as the all 1 bits a a mode of this register. (p.53 ADC data sheet) So the Register definition section looks like this right now:
writeRegister(0x08,0b00000000, 0b00000000);
// define SPI Mode; address of the SDI_CTL_REG Register (hex) and define SPI Mode, ADC data sheet p. 51, matches ARDUINO SPI Mode0
writeRegister(0x10,0b00000000, 0b00000000);
// define DATA_OUT_CTL_REG;
writeRegister(0x14,0b00000000, 0b000000000);
// define Measurement Range ±10,24 V, see p. 54 ADC data sheet;
Sadly this didn’t lead to a different result than 65535.
  byte dataFrame [4];
  // initialise
The initialization is important but you don't do it.
I would try to write a different value to a register and then read that value back. If that doesn't work, a hardware problem might be worth considering.
