I am trying to write and read floating point numbers from an SD card.
I have succeeded to write and recover integers by using
sprintf(tString,"%d,%d,"i,j);
and
sscanf(tString,"%d,%d",&c,&d);
However, when I use the %f token, the floating point number is "printed" as ?
The sscanf always returns 0.00 for the floating point number, even when I hard code the numbers by
sprintf(tString,"2.35,-47.456");
Any ideas?
Thanks,
Gareth
Here is the complete code
SD card read/write
This example shows how to read and write data to and from an SD card file
The circuit:
* SD card attached to SPI bus as follows:
** MOSI - pin 11
** MISO - pin 12
** CLK - pin 13
** CS - pin 4
created Nov 2010
by David A. Mellis
modified 9 Apr 2012
by Tom Igoe
This example code is in the public domain.
#include <SPI.h>
#include <SD.h>
File myFile;
char fName[63];
char tString[32];
char temp[3];
int a;
float c,d;
//char b[10];
int i = 1;
while (!Serial) {
; // wait for serial port to connect. Needed for native USB port only
Serial.print("Initializing SD card...");
if (!SD.begin(4)) {
Serial.println("initialization failed!");
return;
Serial.println("initialization done.");
strcpy(fName,"another/test.txt");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
while (SD.exists(fName))
Serial.println("File already exists");
strcpy(fName,"another/test");
itoa(i++,temp,10);
strcat(fName,temp);
strcat(fName,".txt");
Serial.println(fName);
myFile = SD.open(fName, FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to ");
Serial.print(fName);
sprintf(tString,"%f,-45.756,",2.35);
Serial.println(tString);
myFile.print(tString);
myFile.print("\n");
// close the file:
myFile.close();
Serial.println("...done.");
// if the file didn't open, print an error:
Serial.println("error opening test.txt");
// re-open the file for reading:
myFile = SD.open(fName);
if (myFile) {
Serial.println("test.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
a = (myFile.read());
Serial.print(char(a));
if (a == char(10))
strcat(tString,'\0');
strcat(tString,a);
sscanf(tString,"%f,%f",&c,&d);
Serial.println(c);
Serial.println(d);
// close the file:
myFile.close();
// nothing happens after setup
