Problem with SRF02 UltraSonic Sensor (Arduino Mega 2560)
Hi guys,
I am programming with arduino since 3 months.
The following first programm was working only few days ago, but since i used the second programm, the LED at the back of the SRF02 only signals me its adress but the sensors not ranging anymore. I am not sure if it really has to do with the second code but thats my only explanation.
I also watched the signal send via SDA with an oscilloscope, all i can see there is that only the adress i use in “Wire.startTransmission(adress)” is send as a byte, nothing more.
Another clue, the only part of the programm not working anymore is the if-loop, because only 1 byte is available.
First Programm:
#include <Wire.h>
  Wire.begin();                // join i2c bus (address optional for master)
  Serial.begin(9600);          // Start serielle Kommunikation mit 9600bps
  int Entfernung = 0;
  // step 1: instruct sensor to read echoes
  Wire.beginTransmission(112); // transmit to device #112 (0x70)
                               // the address specified in the datasheet is 224 (0xE0)
                               // but i2c adressing uses the high 7 bits so it's 112
  Wire.write(byte(0x00));      // sets register pointer to the command register (0x00)
  Wire.write(byte(0x51));      // command sensor to measure in "inches" (0x50)
                               // use 0x51 for centimeters
                               // use 0x52 for ping microseconds
  Wire.endTransmission();      // stop transmitting
  // step 2: wait for readings to happen
  delay(70);                   // datasheet suggests at least 65 milliseconds
  // step 3: instruct sensor to return a particular echo reading
  Wire.write(byte(0x02));      // sets register pointer to echo #1 register (0x02)
  // step 4: request reading from sensor
  Wire.requestFrom(112, 2);    // request 2 bytes from slave device #112
  // step 5: receive reading from sensor
  if(2 <= Wire.available())    // if two bytes were received
    Entfernung = Wire.read();  // receive high byte (overwrites previous reading)
    Entfernung = Entfernung << 8;    // shift high byte to be high 8 bits
    Entfernung |= Wire.read(); // receive low byte as lower 8 bits
    Serial.println(Entfernung);   // Entfernung anzeigen
  delay(200);    // wait a bit since people have to read the output :)
Second Programm:
#include <Wire.h>
int Temp;
float UltraGeschw, T, GemesseneCM, KompensierteCM;
  int Laufzeit = 0;
  int Entfernung = 0;
  //Schritt 1: Temperatur berechnen
  Wire.beginTransmission(0x40); //Beginnt Kommunikation mit write: 1000 000 0
  Wire.write(byte(0xF3));       //Gibt Befehl: No Hold Master TemperaturMessung
  Wire.endTransmission();       //Beendet Kommunikation
  delay(90);
  Wire.requestFrom(0x40, 2);  //Fordert 2 bytes von device 0x04 an
  if(2 <= Wire.available())   //falls diese 2 bytes vorhanden sind...
    Temp = Wire.read();  //bytes werden gelesen und als Temp gesetzt
    Temp = Temp << 8;    //byte-Wert wird um 8 bytes verschoben
    Temp |= Wire.read(); //byte Werte werden verglichen und "aufgeodert"
  T = -46.85 + 175.72 / 65536.0 * float(Temp);  //Temperaturmessung mit SHT25
  //Schritt 2: Ultraschallgeschwindigkeit umrechnen
  UltraGeschw = (331.50+0.6*T)*0.0001;          //Temperaturkompensation und Umrechnung von m/s auf cm/µs
  Serial.print(T);
  //Serial.print("  Grad Celsius");
  //Schritt 3: Sensor soll Echosignale lesen
  Wire.beginTransmission(112); // Übermittle an device #112 (0x70)
  Wire.write(byte(0x52));      // command sensor to measure in "inches" (0x50)
                               // Benutze 0x51 für Zentimeter
                               // Benutze 0x52 für Mikrosekunden
  Wire.endTransmission();      // Beendigung der Übertragung
  //Schritt 4: Warten bis Sensor mit ausgelesen werden kann
  delay(70);                   // Datenblatt empfiehlt mindestens 65 ms
  //Schritt 5: Sensor wird angewiesen ein bestimmtes Echnosignal auszuwerten
  //Schritt 6: Es werden 2 bytes vom device angefordert
  //Schritt 7: Daten werden erhalten
  if(2 <= Wire.available())    // falls 2 bytes erhalten wurden
    Laufzeit = Wire.read();      // receive high byte (overwrites previous reading)
    Laufzeit = Laufzeit << 8;    // shift high byte to be high 8 bits
    Laufzeit |= Wire.read();     // receive low byte as lower 8 bits
    //Serial.print(Laufzeit);
    //Serial.print("  µs");
    //Serial.println();
    GemesseneCM = Laufzeit/58;              //Distanz ohne Temperaturkompensation
    Entfernung = Laufzeit/(2/UltraGeschw);  //Distanz mit Temperaturkompensation
    Serial.print(Entfernung);
    //Serial.print("  cm");  // Entfernung in cm anzeigen
    //Serial.print(GemesseneCM);
    //Serial.println();
  delay(5000);    // Zeit in ms die gewartet wird bis Loop neu startet
I hope you can give me an explanation why its not ranging anymore, or why the sensors not using the SDA line properly anymore.
greetings
For your information
does the actual transmission. It returns an int, which can indicate an errorvalue 0== OK. please add some code to check/print the returnvalue
Problem solved. I programmed in Arduino version 1.0.4 but now I tested with arduino version 1.0.5 and there must be a change in the wire library or something like that :)
Good to hear it is working!
In the - http://arduino.cc/en/Main/ReleaseNotes - there is no mention of a fix of the Wire lib in 1.0.5. Is the working code identical to the one you posted above? Otherwise please post the working code for future reference, Thanks,
