Problem with Stalker and Arduino Uno communicate through RF XBee S1 Pro Module
I have a problem making Seeduino stalker V3 and Arduino Uno (could be also two Arduino Unos) communicate each other through XBee S1 Pro module. I have made the following setup:
  1. Configure two Xbee modules to communicate (UartSBee with X-CTU software).
Xbee S1 Pro -> Xbee shield V2.2 (Seeedstudio) -> Arduino UNO (Seeeduino-Stalker v3)-> pc -> x-ctu with this configuration :
The program in the arduino should have an empty Setup() method and an empty loop() method.
xbee shield V2.2 have this configuration :
  • jumper between XB_TX and DIGITAL on the line 1
  • jumper between XB_RX and DIGITAL on the line 0
The X-CTU configuration XBee 1 : PAN ID= 3333, DL=2384, MY=86. XBee 2: PAN ID= 3333, DL=86, MY=2384. Made this communication permanent by writing the setting to internal eeprom
Run X-CTU -> it detect xbee and I was will be able to use it through XCTU.
  1. Then, when I want to use my xbee with arduino IDE (in my case Arduino Uno and Seeduino stalker) . I Use UART software to Tx-Rx between Arduino UNO and Seeeduino Stalker with this wire configuration and Software code
  • plug a jumper wire between xbee XB_TX (pin 11 on the Seeedstudio Xbee Shield V2.2) and arduino TX1 (1) and a jumper wire between xbee XB_RX (pin 10 on the Seeedstudio Xbee Shield V2.2) and arduino RX1 (0)
Then, I pushed to code to both arduino and Stalker. Its not working. Here the code
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10,11); // RX, TX
    pinMode(0, INPUT);
    pinMode(1, OUTPUT);
    mySerial.begin(9600);         // the Bee baud rate
    Serial.begin(9600);           // the terminal baud rate
    if(Serial.available())
       mySerial.print((unsigned char)Serial.read());
    else  if(mySerial.available())
       Serial.print((unsigned char)mySerial.read());
Any help?
Thanks
    pinMode(0, INPUT);
    pinMode(1, OUTPUT);
Don't diddle with the hardware serial pins!
That was wrong. You are talking to the XBee on pins 10 and 11. Do NOT short them to pins 0 and 1. Those pins are for talking to the PC.
I made it to work the code for sender and receiver with this code.
Sender
SoftwareSerial xbee1(3, 2);
void setup( ) {
  Serial.begin( 9600 );
  xbee1.begin( 9600 );
  Serial.println( "Ready!" );
  delay( 500 );
  xbee1.write( "XBee 1 says it's ready!" );
void loop( ) {
  if( Serial.available( ) ) {
    /* If data comes in from serial monitor, send it out to XBee */
    xbee1.write( " it's ready!" );
  if( xbee1.available( ) ) {
    /* If data comes in from XBee, send it out to serial monitor */
    Serial.write( "11111!" );
Receiver
SoftwareSerial xbee1(2, 3 );
void setup( ) {
  delay( 500 );
void loop( ) {
    xbee1.write( Serial.read( ) );
    Serial.write( xbee1.read( ) );
But when I attached a sensor (Animomenter) on the sender and try to send the sensor data to the Receiver it does not receive it. Here the Sender and Receiver code with trying to send a sensor data
Sender
#include <Wire.h>
// ----CONSTANTS (won't change)
#define SENSOR1 A0
//------- VARIABLES (will change)
int sensorValue;
float outVoltage;
int Level;
          sensorValue = analogRead(A0);
          outVoltage = sensorValue * (5.0 / 1023.0);
          delay (50);
          Level = 6*outVoltage;//The level of wind speed is proportional to the output voltage.
          int val = map(Level, 0, 30, 0, 30);
          Serial.println(val);
          delay (500);
          xbee1.write(val);
Reciever
SoftwareSerial xbee1(2, 3);
      delay( 10 );
Any help?
WTF? Map values in the range 0 to 30 to be in the range 0 to 30.
This
   int val = Level * 1;
would make as little sense.
Sending binary data to the serial monitor makes no sense. It ONLY understands ASCII data.
