Problem with string on Serial.print() method
Hi, newbie question here. i've been trying to get a correct output format from my arduino uno. Here's my sketch :
int redPotPin = A0;
int red;
  red = map(analogRead(redPotPin), 0, 1023, 0, 255);
  String txt = red + ";";
  Serial.print(txt);
  delay(250);
I'm expecting to get this output format :
255;254;253; ... ;0;
But instead i've got this random characters :
;;;;;;;ÆÆÆ6Xa'(*(?7:*(?(66Xa'(*(?7:*(?
So, is there anything wrong with my sketch ?
Just what are you trying to do?
Thanks for replying
I'm simply trying to get a value from a potentiometer (i'm planning to use three). And then read that value from a java application, which will change the background color of the frame from black (when the value is 0) up to red (when the value is 255).
Doing map from 0-1023 to 0-255 is an awfully inefficient way of shifting right by 2. Also, why bother using String object? Why not just print the number and the print the semicolon?
const int redPotPin = A0;
int red;
  Serial.print (red);
  Serial.print (";");
  delay(250);
Plus what Arrch said about map.
  red = analogRead (redPotPin) >> 2;
