problem with String::replace
Why does the first line below compile and not the second? The p comes from AsyncWebServerRequest::getParam which returns a struct with a String. I tried wrapping 'b' and '0' with String() but it didn't help.
      char debug = p->name().toInt();
      char idx = p->name().replace('b','0').toInt();
The error message is:
error: passing 'const String' as 'this' argument of 'void String::replace(char, char)'
discards qualifiers [-fpermissive]
I do not know what the error message means but this:
is a clue. The replace method does not return anything. That is what the documentation says also:
Returns
none
It looks like you need to do this in multiple steps:
String temp = p->name() ;
temp.replace('b','0') ;
char idx = temp.toInt();
although I am a little concerned because:
(1) The usual recommendation is to not use String on an Arduino.
(2) The toInt() method of String is documented to return a long. Storing the result in a char could be risky.
I do not use String so I may have this completely wrong. Good Luck!
Because toInt() does not modify the String instance, and replace() does.
It appears as though p->name() returns a const String (or whatever it does return gets converted to a const String). You can't modify a const String.
