Problem with String.startsWith functions
Hi there.
I am facing problems with the .startsWith functions
These are my codes:
void setup(){
String apple = "doctors hate me";
if (apple.startsWith="doctors"){
Serial.println(apple);
void loop(){}
Problem:
-the .startsWith does not turn orange in the Arduino IDE which surely is an indication of trouble.
-i get the error message of "invalid use of member (did you forget the '&'?)" at that line of code.
Do i need to initialise any libraries or update anything for this to work?
I am using Arduino 1.0.6 to go with Arduino micro
This looks wrong.
Check the definition of the startsWith( ) function of the String class.
The startsWith function requires a string argument and returns true or false.
if ( apple.startsWith( "doctors" ) )
   //  do something
Also, any test for equality inside an if( ) uses double == .
I suggest that instead of blundering around aimlessly using random keystrokes, you get hold of an elementary C/C++ programming book and read it.
