Problem with structures
Hello,
I recently start to use IDE above 1 version, till now i have used 023 version of Arduino IDE. The following code works on 023 but doesn't on 1.0.4 and i will appreciate if someone will explain why and how to fix the problem
after the includes and defines at the begining of the sketch i have
typedef struct TextVal
  uint16_t Value;//crt value
  uint16_t MaxVal;//maximum value for the setting
then i use the structure in one array
TextVal ROM_Shadow[52];
and this array is used in several functions like the one below
//Description: Updates DigiText Object value
//Parameters: TextVal structure
//Returns: None
void UpdateDigi(TextVal &MyVal)
  if(CrtDigi == 255)
    return;
  if(Digi[CrtDigi].GetDigiBorder())
    Digi[CrtDigi].SetDigiValue(MyVal.Value);
    if(ROM_Shadow[ROM_Buzz].Value)
      Serial.print('S');//Play Beep
when compiling i get errors for all the functions similar with the one above
GVI_Remote_Touch:98: error: variable or field 'UpdateDigi' declared void GVI_Remote_Touch:98: error: 'TextVal' was not declared in this scope GVI_Remote_Touch:98: error: 'MyVal' was not declared in this scope GVI_Remote_Touch:99: error: variable or field 'SmallPlus' declared void GVI_Remote_Touch:99: error: 'TextVal' was not declared in this scope GVI_Remote_Touch:99: error: 'MyVal' was not declared in this scope
Thanks for your help
Your typedef statement looks wrong to me. The typedef name needs to go at the end.
For your declaration, try
struct TextVal  Rom_shadow[52];
and see if that works.
I'd also declare that function with argument type struct TextVal* and give it a pointer to the structure instance rather than copy the whole structure.
after a lot of searches i Found the solution
  1. create a Header file and put the structure definition in it (h file in the same folder as the sketch)
#ifndef Functions_h
#define Functions_h
#endif
the in the main code add
#include "Functions.h"
and it works...
You can make a function prototype and then it compiles in one file. This compiles OK for example:
void UpdateDigi(TextVal &MyVal);  // <----- add this
// whatever
void setup () { }
void loop () { }
Thanks Nick, i will try this.
michinyon, can you please explain in detail this
[quote author=Nick Gammon link=topic=156263.msg1170848#msg1170848 date=1364163621] You can make a function prototype and then it compiles in one file. This compiles OK for example: [/quote]
Is that behaviour version-specific? With 1.0.1 I seem to get the autogenerated prototypes added (in the wrong place) for all functions regardless of whether I included my own prototypes, so it's not possible to use user-defined types in a function signature unless the types are declared in a header file. (Your example won't compile for me.)
Yes it's a new feature. 1.0.3 onwards, I think.
Thanks Nick,
Your suggestion works
