Problem with switch/case statement
Dear Sir,
I'm having a problem with the switch / case condition at the end of the statement. I have to get around, to run well.
Returns a memory problem.
// THIS WORK WITH MEMORY PROBLEMS
switch (i) {
case 0x0218: case 0xA3B4: case 0xE03C: case 0xE066: case 0x106A:
case 0x1133: case 0x1A4A: case 0x1E5D:
case 0xAA25: case 0xE227: case 0x1229: case 0xA25D:
case 0x26AC:
// LONG DATA +/- 800 CASES
case 0x064:
case 0x12FC: case 0x1B37: case 0x1C5A: case 0x1D64:
case 0x2C32: case 0x2B3F: case 0x2C40:
case 0x33C5: case 0x3B3E: case 0xA33F: case 0x36C1:
case 0xC433: case 0x4F35: case 0x439A: case 0x45C3:
case 0x55B3: case 0x5F5C: case 0x567A: case 0xA571: case 0x5C73:
case 0x671:
return 142;
default: return 0;
// THIS WORKS...
switch (i) {
case 0x26AC:
default: switch (i) {
case 0x064:
case 0x671:
return 142;
default: return 0;
Thanks,
Helder Rodrigues
I have no idea what that means.
Please remember to use code tags when posting code.
Don't post snippets.
          return 142 Lacks a semicolon
i just made a brief copy the ; is there
suminonif:
Get back when you've got a proper question and set of details
enough said
READ AND FOLLOW THE POSTING RULES THEY APPLY TO YOU!
Mark
WITH THE PROBLEM
Sketch uses 5326 bytes ...
Global variables uses 1894 bytes (92%) ...
Low memory available, stability problems may occur.
WITH THE SUB SWITCH/CASE
Sketch uses 8054 bytes ...
Global variables uses 264 bytes (12%) ...
Please start making sense
