You may want to add the option where the password times out after a period of time if no button has been pressed.
larryd, Can you have a look over my code. I've got it working the way I want it to, but only if I do things in the order they are supposed to happen. As soon as an incorrect password is entered the PW variable starts storing random numbers that don't get cleared. This is slightly baffling because at every stage in the code the PW variable is supposed to get set to zero, but that aint happening.
Can you spot anything?
#include <Keypad.h>
#include <EEPROMex.h>
const byte ROWS = 4; //four rows
const byte COLS = 3; //three columns
char keys[ROWS][COLS] =
{'1', '2', '3'},
{'4', '5', '6'},
{'7', '8', '9'},
{'*', '0', '#'}
byte rowPins[ROWS] = {A0, A1, A2, A3}; //connect to the row pinouts of the keypad
byte colPins[COLS] = {4, 3, 2}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
const byte relayOne = 8;
const byte relayTwo = 9;
//Target password
unsigned int masterPassWord = 1234;
unsigned int PassWord;
unsigned int newPassWord;
int address;
//Password number entered
unsigned int PW;
bool PWokay = false;
bool masterPWokay = false;
pinMode(relayOne, OUTPUT);
pinMode(relayTwo, OUTPUT);
digitalWrite(relayOne, HIGH);
digitalWrite(relayTwo, HIGH);
keypad.addEventListener(keypadEvent); //Add an event listener for this keypad
newPassWord = EEPROM.readInt(address);
if(newPassWord > 0){
PassWord = newPassWord;
else{
PassWord = masterPassWord;
Serial.println(masterPassWord);
Serial.println(PassWord);
Serial.println("Enter password");
char key = keypad.getKey();
if (key)
Serial.print(key);
//check for a valid password
if ((key == '*' || key == '#') && (PWokay == false || masterPWokay == false))
if (PW == PassWord || PW == masterPassWord)
if(PW == masterPassWord){
masterPWokay = true;
Serial.println("Master password is ok");
else{
PWokay = true;
Serial.println("");
Serial.println("Password is okay.");
masterPassWord = false;
PWokay = false;
PW = 0;
Serial.println("");
Serial.println("Password is bad.");
//assemble the password number
if (PWokay == false || masterPWokay == false && key >= '0' && key <= '9')
PW = PW * 10 + (key - '0');
Serial.print(" ");
Serial.println(PW);
void keypadEvent(KeypadEvent key)
switch (keypad.getState())
case RELEASED:
switch (key)
//only if there is a valid password
case '*':
if (PWokay == true)
//relayOne OFF
PWokay = false;
PW = 0;
if (masterPWokay == true)
PWokay = false;
PW = 0;
case '#':
if (PWokay == true)
//relayTwo OFF
PWokay = false;
PW = 0;
} //END of switch (key)
break; //END of RELEASED
case HOLD:
switch (key)
case '*':
if (PWokay == true)
//relayTwo ON
digitalWrite(relayOne, LOW);
Serial.print("Enter new password: ");
unsigned long passWorddelay = millis();
while(millis() - passWorddelay < 6000)
if (key)
Serial.print(key);
if (key == '*')
EEPROM.writeInt(address,PW);
Serial.print("New password: ");
Serial.println(newPassWord);
Serial.print("New password confirmed as: ");
if (masterPWokay == false && key >= '0' && key <= '9')
PWokay = false;
PW = 0;
case '#':
if (PWokay == true)
//relayTwo ON
digitalWrite(relayTwo, LOW);
break; //END of HOLD
} //END of switch (keypad.getState())
} //END of k e y p a d E v e n t ( )
If anyone else can spot what the problem is please let me know?
Cheers.
Ok finally got the sketch working the way I want. It may not be the best solution, but it works. I do a software reset if the master password is entered, then add new password within setup while loop. Doing this seems to have cleared up the random bugs I was getting.
Here is the code if anyone is interested:
#include <Keypad.h>
{'1', '2', '3'},
{'4', '5', '6'},
{'7', '8', '9'},
{'*', '0', '#'}
//Target password
unsigned int PW;
int address;
while(millis() - passWorddelay < 10000)
if (key)
Serial.print(key);
if (key == '*')
PWokay = false;
PW = 0;
if (key)
Serial.print(key);
if ((key == '*' || key == '#') && PWokay == false)
Serial.println("Master password ok");
else{
PWokay = true;
Serial.println("");
PWokay = false;
PW = 0;
Serial.println("");
if (PWokay == false && key >= '0' && key <= '9')
case RELEASED:
switch (key)
case '*':
if (PWokay == true)
//relayOne OFF
PWokay = false;
PW = 0;
software_Reset();
case '#':
if (PWokay == true)
//relayTwo OFF
PWokay = false;
PW = 0;
PWokay = false;
PW = 0;
case HOLD:
switch (key)
case '*':
if (PWokay == true)
//relayTwo ON
case '#':
if (PWokay == true)
//relayTwo ON
void software_Reset() // Restarts program from beginning but does not reset the peripherals and registers
asm volatile (" jmp 0");
Cheers.
