Problem with Task after Countdown
my current project is a Dice (with LED and LCD) with an Countdown Timer for TableTop Games.
The Dice works perfect, also i found a cool Countdown with adjustable Time, but unfortunately does the action when the countdown is finished not properly work.
I would like, if the countdown is at zero - a piezo gaves a tone until a stop - button is pressed.
But now the piezo (in the code i use a LED at the moment - is less annoying for the tests) is only silent when the
countdown is running.
Shortly after boot it starts to sound. I press the start button, the countdown starts and the piezo is silent.
After the countdown the piezo starts - as it should - but never stopps.
I fear that my idea is not possible with this countdown code, so i have to take another one?
Does anyone have a solution to make it possible with this code?
I tried to add another variable, like the countrun variable, but the only result was a never stopping looping countdown.
Thank you very much for your effort
The code exceeds the maximum allowed post length so i attach it as a txt.
Best Chris
lcddice.txt (10.5 KB)
It really isn't necessary to comment EVERY line. Some things are just plain obvious.
It IS necessary to use Tools + Auto Format BEFORE posting code. It is necessary to remove commented out code.
Sry, the reason for the mass of comments was for documentation for myself
I removed the comments and cleaned the code with Auto Format:
// Arduino code by ChMik
// Led Würfel mit LCD Anzeige und
// Timer mit akustischem Ton With Arduino
// based on Arduino Led Dice by Davuzz11
// http://www.instructables.com/id/Arduino-Led-Dice/
// and Erstes eigenes Projekt by squaremeter
// http://forum.arduino.cc/index.php?topic=71395.0
#include <LiquidCrystal.h>
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
int pinLeds1 = 10;
int pinLeds2 = 9;
int pinLeds3 = 8;
int pinLeds4 = 7;
int buzzer = 6;
int d = 0;
char alarm = 0;
int buttonPin = 16;
int const buttonPin2 = 15;
int const buttonPin3 = 17;
int varpin = A0;
int countrun;
int buttonState;
int buttonState2;
int buttonState3;
boolean debug = 1;
long ran;
const int rand_sequence[] = {
  0, 1, 0, 6, 0, 2, 0, 5, 0, 3, 0, 4,
const int rand_sequence_len = (sizeof(rand_sequence) / sizeof(rand_sequence[0]));
int long countdowntime;
int val;
int lastval;
int long minutes;
int long seconds;
volatile unsigned char tick;
int inputtime ;
ISR (TIMER2_OVF_vect)
  ++tick;
void setup ()
  pinMode (pinLeds1, OUTPUT);
  pinMode (pinLeds2, OUTPUT);
  pinMode (pinLeds3, OUTPUT);
  pinMode (pinLeds4, OUTPUT);
  pinMode (buzzer, OUTPUT);
  pinMode (buttonPin, INPUT);
  pinMode(15,INPUT);
  pinMode(17,INPUT);
  int buttonPin = digitalRead(16);
  int buttonPin2 = digitalRead(15);
  int buttonPin3 = digitalRead(17);
  inputtime = analogRead(varpin);
  countdowntime = 0;
  countrun = 1;
  lcd.begin(16, 2);
  lcd.print("T: 01:00  W:");
  lcd.setCursor(3, 0);
  readAin();
  lcd.setCursor(0,1);
  lcd.print("C: 00:00");
  if (debug){
    Serial.print("Setup Complete\n");
  buttonState = digitalRead(buttonPin);
  buttonState2 = digitalRead(buttonPin2);
  buttonState3 = digitalRead(buttonPin3);
  val = digitalRead(tick);
  Serial.println(countrun);
  if (buttonState2 != HIGH & countrun == 1)
    lcd.setCursor(0,0);
    lcd.print("T: ");
    lcd.setCursor(0, 1);
    lcd.print("C:");
    if (countdowntime<=0 & countrun == 1);
      // tone(buzzer, 140);             //Final Usage ?
      digitalWrite (buzzer, HIGH);
      Serial.print(countdowntime);
      Serial.print(lastval);
    if (countdowntime>0 & countrun == 1)
      if (val != lastval)
              countdowntime--;
        digitalWrite (buzzer, LOW);
        // noTone (buzzer);
      lcd.setCursor(0,1);
      printTime();
      val = lastval;
    lcd.setCursor(0,0);
    lcd.print("S: ");
    readAin();
    countdowntime = inputtime;
    //countrun = 1;
  /* if (buttonState3 == HIGH) {            //Attemp to solve the Countdown-Finish Problem
   countrun = 0;
  if (buttonState == HIGH) {
    randomSeed(analogRead(5));
    ran = random(6) + 1;
        displayRandomSequence();
    // Flash the number a few times
    displayNum(ran);
    delay(200);
    displayNone();
    delay(200);
    displayNum(ran);
    delay(200);
    displayNone();
    delay(200);
    displayNum(ran);
  delay(50);
void printTime ()
  minutes = countdowntime/60;
  seconds = countdowntime%60;
  if (minutes<10)
    lcd.print("C: 0");
  lcd.print(minutes);
  lcd.print(":");
  if (seconds<10)
    lcd.print("0");
    lcd.print(seconds);
    lcd.write(' ');
    lcd.print(seconds);
    lcd.print(" ");
void readAin ()
  int showminutes = inputtime /60;
  int showseconds = inputtime %60;
  if (showminutes<10)
    lcd.print('0');
  lcd.print(showminutes);
  lcd.print(":");
  if (showseconds<10)
    lcd.print("0");
    lcd.print(showseconds);
    lcd.write('  ');
    lcd.print(" ");
  delay(150);
void displayRandomSequence() {
  for (int i=0; i < rand_sequence_len; i++) {
    displayNum(rand_sequence[i]);
    delay(100);
void displayNone() {
  // Clear the output
  digitalWrite (pinLeds1, LOW);
  digitalWrite (pinLeds2, LOW);
  digitalWrite (pinLeds3, LOW);
  digitalWrite (pinLeds4, LOW);
void displayOne() {
  // Display 1
  digitalWrite (pinLeds4, HIGH);
void displayTwo() {
  // Display 2
  digitalWrite (pinLeds1, HIGH);
void displayThree() {
  // Display 3
  digitalWrite (pinLeds3, HIGH);
void displayFour() {
  // Display 4
void displayFive() {
  // Display 5
void displaySix() {
  // Display 6
  digitalWrite (pinLeds2, HIGH);
void displayNum(int num) {
  // Displays num
  switch (num) {
  case 1:
    displayOne();
    lcd.setCursor(14,0);
    lcd.print(num);
  case 2:
    displayTwo();
    lcd.print(num);
  case 3:
    displayThree();
    lcd.print(num);
  case 4:
    displayFour();
    lcd.print(num);
  case 5:
    displayFive();
    lcd.print(num);
  case 6:
    displaySix();
    lcd.print(num);
  default:
    displayNone();
  // Serial.println(num);
