I connected a temperature sensor LM 35 (centigrade scale) temperature sensor. I connected its pins correctly. When I use the following code I am getting a value of 6 in Serial port.Is something wrong with my sensor or is it the code? .Can some one point out what's wrong.
int tempPin = 0;
int temp;
temp = analogRead(tempPin)/10;
Serial.println(temp);
I connected the pins with a breadboard and jumper wire .
The room temperature is around 30 degrees.
I connected the first pin to 5 volts second pin to A0 and the third pin to GND.
There seems to be something wrong with analog read.
I'm sorry. Looks like I used the wrong formula. I used the formula in the above link and everything works fine. It shows that the room temperature is 33 degrees now which is correct.
The formula was " tempC = (5.0 * tempC * 100.0)/1024.0; "
