#include <Wire.h>
#include <hd44780.h>
#include <hd44780ioClass/hd44780_I2Cexp.h>
#include <Encoder.h>
#include <max6675.h> // Include the MAX6675 library
// Define pins for Rotary Encoder
#define ROTARYPIN1 2
#define ROTARYPIN2 3
#define ROTARYSWITCH 4
// LCD setup
hd44780_I2Cexp lcd;
// Encoder setup
Encoder encoder(ROTARYPIN1, ROTARYPIN2);
long lastPosition = -999;
// MAX6675 setup
int thermoDO = 5;
int thermoCS = 6;
int thermoCLK = 7;
MAX6675 thermocouple(thermoCLK, thermoCS, thermoDO);
// System settings
float temperatureThreshold = 0.0;
int wateringDuration = 5;
int wateringInterval = 5;
bool pumpStatus = false; // false = OFF, true = ON
// Pump control variables
unsigned long lastPumpTime = 0; // Last time the pump was activated
bool pumpActive = false; // Current status of the pump
// Variable to store the current menu page
int currentPage = 0;
bool buttonPressed = false;
unsigned long buttonPressTime = 0;
const unsigned long longPressDuration = 1000; // Long press duration in milliseconds
const unsigned long debounceDelay = 50; // Debounce delay in milliseconds
unsigned long lastDebounceTime = 0;
// Timer variables for temperature update
unsigned long lastTempUpdateTime = 0;
const unsigned long tempUpdateInterval = 1000; // Update temperature every second
// Initialize Wire library
Wire.begin();
// Initialize LCD
lcd.begin(20, 4);
lcd.clear();
// Set LCD backlight brightness (0-255, 0 = off, 255 = max brightness)
lcd.setBacklight(5); // Set backlight brightness to 5
// Initialize encoder
encoder.write(0);
// Show initial page
displayPage();
long newPosition = encoder.read();
if (newPosition != lastPosition) {
if (!buttonPressed && currentPage != 6) { // Ignore encoder when on page 6
adjustValue(newPosition);
lastPosition = newPosition;
// Check for button press
if (digitalRead(ROTARYSWITCH) == LOW && !buttonPressed) {
buttonPressed = true;
buttonPressTime = millis();
// Check for button release
if (digitalRead(ROTARYSWITCH) == HIGH && buttonPressed) {
if (millis() - buttonPressTime >= debounceDelay) {
if ((millis() - buttonPressTime) < longPressDuration) {
// Short click
handleShortClick();
// Long click
handleLongClick();
// Check the pump status continuously
updatePumpStatus();
// Update temperature continuously in case 6
if (currentPage == 6) {
displayPage();
void adjustValue(long newPosition) {
// Adjust value based on encoder rotation
if (newPosition > lastPosition) {
// Increase value
switch (currentPage) {
case 2:
if (temperatureThreshold < 255.0) {
temperatureThreshold += 0.1;
case 3:
if (wateringDuration < 255) {
wateringDuration += 1;
case 4:
if (wateringInterval < 255) {
wateringInterval += 1;
default:
displayPage();
} else if (newPosition < lastPosition) {
// Decrease value
case 2:
if (temperatureThreshold > 0.0) {
temperatureThreshold -= 0.1;
case 3:
if (wateringDuration > 0) {
wateringDuration -= 1;
case 4:
if (wateringInterval > 0) {
wateringInterval -= 1;
default:
displayPage();
void handleShortClick() {
if (currentMillis - lastDebounceTime > debounceDelay) {
lastDebounceTime = currentMillis;
// Toggle between page 5 and 6 when either is the current page
if (currentPage == 5) {
currentPage = 6;
} else if (currentPage == 6) {
currentPage = 5;
currentPage++;
if (currentPage > 6) currentPage = 0;
displayPage();
void handleLongClick() {
// Handle long click only on allowed pages
if (currentPage > 2) {
currentPage = (currentPage == 0) ? 6 : currentPage - 1; // Navigate to previous page or last page if currently on the first page
displayPage();
void updatePumpStatus() {
float currentTemp = readTemperature();
unsigned long currentTime = millis();
if (currentTemp > temperatureThreshold && currentTime - lastPumpTime > wateringInterval * 3600000UL && !pumpActive) {
pumpActive = true;
lastPumpTime = currentTime;
lcd.setCursor(0, 1);
lcd.print("PUMP: ON ");
} else if (pumpActive && currentTime - lastPumpTime >= wateringDuration * 1000UL) {
pumpActive = false;
lcd.print("PUMP: OFF ");
void displayPage() {
lcd.clear();
case 0:
lcd.print("Temp-Based System");
case 1:
lcd.print("Click to Start Setup");
case 2:
lcd.print("Threshold: "); lcd.print(temperatureThreshold); lcd.print(" C");
lcd.print("CLICK TO CONFIRM");
case 3:
lcd.print("Duration: "); lcd.print(wateringDuration); lcd.print(" sec");
case 4:
lcd.print("Interval: "); lcd.print(wateringInterval); lcd.print(" hr");
case 5:
lcd.print("Review Settings");
lcd.setCursor(0, 2);
lcd.setCursor(0, 3);
case 6:
// Update temperature display every time page 6 is displayed
lcd.print("Temperature: "); lcd.print(readTemperature()); lcd.print(" C");
lcd.print(pumpActive ? "PUMP: ON" : "PUMP: OFF");
default:
currentPage = 0;
displayPage();
float readTemperature() {
return thermocouple.readCelsius(); // Read temperature from MAX6675 sensor
Can anyone help me understand why the temperature in case 6 does not update continuously?
