Problem with the code for DS18S20 sensor.
Hello
I´ve got a problem with a DS18S20 sensor. I´ve used a code from an already existing project but it were built for an DS18B20 sensor.
When I run the code it works but I cant get the right value from the sensor. I run the sensor in a room (21 C degrees) but the sensor says 26 C degrees. Please someone help me. I think I must have missed something in the code that only works for a DS18B20. Hope you understand my bad english :slight_smile:
#define TEMP_PIN 5 //
void OneWireReset(int Pin);
void OneWireOutByte(int Pin, byte d);
byte OneWireInByte(int Pin);
digitalWrite(TEMP_PIN, LOW);
pinMode(TEMP_PIN, INPUT); // sets the digital pin as input (logic 1)
delay(100);
Serial.print(“Temperatur:\n”);
void loop(){
int HighByte, LowByte, TReading, SignBit, Tc_100, Whole, Fract;
OneWireReset(TEMP_PIN);
OneWireOutByte(TEMP_PIN, 0xcc);
OneWireOutByte(TEMP_PIN, 0x44); // perform temperature conversion, strong pullup for one sec
OneWireOutByte(TEMP_PIN, 0xbe);
LowByte = OneWireInByte(TEMP_PIN);
HighByte = OneWireInByte(TEMP_PIN);
TReading = (HighByte << 8) + LowByte;
SignBit = TReading & 0x8000; // test most sig bit
if (SignBit) // negative
TReading = (TReading ^ 0xffff) + 1; // 2’s comp
Tc_100 = ((TReading*100/2)); // multiply by 0.5
Whole = Tc_100 / 100; // separate off the whole and fractional portions
Fract = Tc_100 % 100;
if (SignBit) // If its negative
Serial.print("-");
Serial.print(Whole);
Serial.print(".");
if (Fract < 10)
Serial.print(“0”);
Serial.print(Fract);
Serial.print("\n");
delay(5000);
void OneWireReset(int Pin) // reset. Should improve to act as a presence pulse
digitalWrite(Pin, LOW);
pinMode(Pin, OUTPUT); // bring low for 500 us
delayMicroseconds(500);
pinMode(Pin, INPUT);
void OneWireOutByte(int Pin, byte d) // output byte d (least sig bit first).
byte n;
for(n=8; n!=0; n–)
if ((d & 0x01) == 1) // test least sig bit
delayMicroseconds(5);
delayMicroseconds(60);
d=d>>1; // now the next bit is in the least sig bit position.
byte OneWireInByte(int Pin) // read byte, least sig byte first
byte d, n, b;
for (n=0; n<8; n++)
b = digitalRead(Pin);
delayMicroseconds(50);
d = (d >> 1) | (b<<7); // shift d to right and insert b in most sig bit position
return(d);
//Will_jr
Temperature can fluctuate locally although 5 degrees is quite much. Does the IC feel hot? Or is it near a hot powersupply, laptopFan , ...?
There may be a problem with the precision (number of bits) as the 18S20 supports only 9 bits and the 18B20 supports 9..12 bit. Check the datasheet to see if the formulas and bit positions are identical. As far as I recall they are, and the code looks OK.
The Dallas Temperature Library support both IC's. Install it and you would have an alternative reference. - http://milesburton.com/index.php/Dallas_Temperature_Control_Library
Finally you can make displaying the Temp easier with a float var
float Temperature = TReading * 0.5; Serial.println(Temperature, 1); // print with 1 bit precision
give it a try
