Problem with the keyboard midi out project
Hi, I got an organ keyboard and wanted to get a midi out to connect it to the PC, which I got to work but with the press of a only one key at a time.
The problem comes when two keys or more of the same row are pressed, it gives a strange or badly sounding key, however there are no problems when doing so when several in the same column coincide.
I have searched the internet to see if there was any solution and I have not found anything, I do not know if it will be a problem of the code or the circuit, I may be missing some diode, the tests I have done have not gone well, I leave the code and the circuit, of which I can put more images, thanks.
//   #define NUM_ROWS 6
//   #define NUM_COLS 11
#define NUM_COLS 4
#define NUM_ROWS 8
#define NOTE_ON_CMD 0x90
#define NOTE_OFF_CMD 0x80
#define NOTE_VELOCITY 127
//MIDI baud rate
#define SERIAL_RATE 31250
// Pin Definitions
// Row input pins
const int COL1Pin = 2;
const int COL2Pin = 3;
const int COL3Pin = 4;
const int COL4Pin = 5;
//const int row5Pin = 6;
//const int row6Pin = 7;
// 74HC595 pins
const int dataPin = 8;
const int latchPin = 9;
const int clockPin = 10;
boolean keyPressed[NUM_ROWS][NUM_COLS];
uint8_t keyToMidiMap[NUM_ROWS][NUM_COLS];
// bitmasks for scanning columns
int bits[] =
  B00000001,
  B00000010,
  B00000100,
  B00001000,
  B00010000,
  B00100000,
  B01000000,
  B10000000
  int note = 36;
  for(int colCtr = 0; colCtr < NUM_COLS; ++colCtr)
    for(int rowCtr = 0; rowCtr < NUM_ROWS; ++rowCtr)
      keyPressed[rowCtr][colCtr] = false;
      keyToMidiMap[rowCtr][colCtr] = note;
      note++;
  // setup pins output/input mode
  pinMode(dataPin, OUTPUT);
  pinMode(clockPin, OUTPUT);
  pinMode(latchPin, OUTPUT);
  pinMode(COL1Pin, INPUT);
  pinMode(COL2Pin, INPUT);
  pinMode(COL3Pin, INPUT);
  pinMode(COL4Pin, INPUT);
  //pinMode(row5Pin, INPUT);
 // pinMode(row6Pin, INPUT);
  Serial.begin(SERIAL_RATE);
  for (int rowCtr = 0; rowCtr < NUM_ROWS; ++rowCtr)
    //scan next column
    scanrow(rowCtr);
    //get row values at this column
    int colValue[NUM_COLS];
    colValue[0] = digitalRead(COL1Pin);
    colValue[1] = digitalRead(COL2Pin);
    colValue[2] = digitalRead(COL3Pin);
    colValue[3] = digitalRead(COL4Pin);
//    rowValue[4] = digitalRead(row5Pin);
 //   rowValue[5] = digitalRead(row6Pin);
    // process keys pressed
    for(int colCtr=0; colCtr<NUM_COLS; ++colCtr)
      if(colValue[colCtr] != 0 && !keyPressed[rowCtr][colCtr])
        keyPressed[rowCtr][colCtr] = true;
        noteOn(rowCtr,colCtr);
    // process keys released
      if(colValue[colCtr] == 0 && keyPressed[rowCtr][colCtr])
        noteOff(rowCtr,colCtr);
void scanrow(int rowNum)
  digitalWrite(latchPin, LOW);
  if(0 <= rowNum && rowNum <= 7)
    shiftOut(dataPin, clockPin, MSBFIRST, B00000000); //right sr
    shiftOut(dataPin, clockPin, MSBFIRST, bits[rowNum]); //left sr
    shiftOut(dataPin, clockPin, MSBFIRST, bits[rowNum-8]); //right sr
    shiftOut(dataPin, clockPin, MSBFIRST, B00000000); //left sr
  digitalWrite(latchPin, HIGH);
void noteOn(int row, int col)
  Serial.write(NOTE_ON_CMD);
  Serial.write(keyToMidiMap[row][col]);
  Serial.write(NOTE_VELOCITY);
void noteOff(int row, int col)
  Serial.write(NOTE_OFF_CMD);
Can it be that i have not a diode in the buttons of the keyboard or diodes in the circuit?
