Hello!
I have a problem with my lcd SSD1963. 7 inches
When I push in the screen in the same point repetitively, the screen doesn't work fine.
For example, if I push 5 times in a keyboard designed, in one number, probably one of the times other number will be set.....
Have you tried dumping the touch values to serial monitor? How much variation are we talking about? If you are getting valid results MOST of the time, with the OCCASIONAL 'glitch' that is normal.
In my opinion, it happens more than I expect to be normal....
For example in the Utouch library, when i download a sketch with a keypad, if i push 5 times the key 1, sure that at least one of the times another key will be pushed.......
Maybe it happens because is a resistor tft??
Is better a capacitive tft???
To be honest my display is only 5", if i use my finger I get errors sometimes, but if I use some sort of stylus, I have no problems, are you using your finger to press the screen?
