Problem with the tachometer
i wrote the code for the tachometer and works fine, now i am try to implement is with another code that includes a menu, after that the tachometer is not working correct, can you help me with that ? i attache my code
thanks
sketch_mar31a.ino (3.37 KB)
i attache my code
Please can you read this before posting a programming question and post the code here using [ code ] tags
Hi, i read that , now i am also adding the code as you mention
thanks
L
// include the library code:
#include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
//FOR CHANGING THE MENU-------------------------------------------
int inPin = 6;
int buttonState = 0;
int lastButtonState = 0;
int page = 0;
//FOR THE DIFFERENCE OUTPUT-------------------------------------
int inPinOut = 9;
//for tacho ----------------------------------------------------
const int sensorPin = 10;
const int sensorInterrupt = 0;
const int timeoutValue = 5;
volatile unsigned long lastPulseTime;
volatile unsigned long interval = 0;
volatile int timeoutCounter;
  // set up the LCD's number of columns and rows:
  lcd.begin(16, 2);
  // declare pushbutton as input
  pinMode(inPin, INPUT);
  pinMode (inPinOut, OUTPUT);
//for tacho---------------------------------------------------
 pinMode(sensorPin, INPUT);
 digitalWrite(sensorPin, HIGH);    // enable internal pullup (if Hall sensor needs it)
 attachInterrupt(sensorInterrupt, sensorIsr, RISING);
 lastPulseTime = micros();
 timeoutCounter = 0;
void sensorIsr()
 unsigned long now = micros();
 interval = now - lastPulseTime;
 lastPulseTime = now;
 timeoutCounter = timeoutValue;
  buttonState = digitalRead(inPin);
  lcd.setCursor(0,0);
 Serial.print(" RPM ");
 if (timeoutCounter != 0)
   --timeoutCounter;
   float rpm = 60e6/(float)interval;
   Serial.print(rpm, 1);
//PRESSURE SENSORS----------------------------------------------------------
float sensorVoltage = analogRead(0);   // read the sensor voltage from analog pin 0 pump pressure
int Ppsi = ((sensorVoltage-95)/204)*50/4;
float sensorVoltage2 = analogRead(1);   // read the sensor voltage from analog pin 1 pressure from the filter
int Fpsi = ((sensorVoltage2-95)/204)*50/4;
int DpsiBar = (Ppsi-Fpsi);
int Dpsi = ((DpsiBar*100)/Ppsi);
float sensorVoltage3 = analogRead(2);   // read the sensor voltage from analog pin 2 for Max Pressure Difference
int PDL = ((sensorVoltage3)/1023)*10;
//Pressure comparator
if (DpsiBar >= PDL)
  digitalWrite(inPinOut, HIGH);
  digitalWrite(inPinOut, LOW);
  switch (page) {
    case 0:
lcd.print ("Pump Pressure");
lcd.setCursor (0,1);
lcd.print (Ppsi);
lcd.print (" BAR");
Serial.println (Ppsi);
delay (500);
    case 1:
lcd.print ("Filter Pressure");
lcd.print (Fpsi);
lcd.print (" BAR");
delay (500);
    case 2:
lcd.print ("Filter Pres Diff");
lcd.print (Dpsi);
lcd.print (" %    ");
lcd.print (DpsiBar);
lcd.print (" BAR");
delay (500);
    case 3:
lcd.print ("Pressure Dif Limit");
lcd.print (PDL);
lcd.print (" BAR");
delay (500);
    case 4:
lcd.print ("Speed");
lcd.print (rpm);
lcd.print (" RPM");
delay (100);
    case 5:
lcd.print ("rilter Pressure");
lcd.print (Fpsi);
lcd.print (" BAR");
delay (500);
 if (buttonState != lastButtonState)     // compare the buttonState to its previous state
    delay(800);               // if the state has changed, increment the counter
    if (buttonState == HIGH)
    lcd.clear();
      page++;     // if the current state is HIGH then the button changed
      if(page==6)
        page=0;
quite difficult to understand the issue :frowning:
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);The LCD uses pin 2
  attachInterrupt(sensorInterrupt, sensorIsr, RISING);So does the interrupt
UKHELIBOB,
what do you mean ? i did not get you :frowning:
thanks
Lazaros
The LCD uses pin 2
You are using interrupt 0, which on most Arduinos (you don't say which you are using), uses pin 2
Which board are you using and which pin is the tachometer connected to ?
i am using Arduino Uno R3 and the tachometer is connected on pin 10
thanks
Lazaros
Then it will never cause interrupt 0 to be triggered.
i also add it as
const float sensorInterrupt = 10;
but did not work
here is my last attempt that work but only on pin 1 and 0 , i have to move the lcd pins on other pins
LiquidCrystal lcd(12,11,7,6,5,4);
int inPin = 8;
int page = 0;
int inPinOut = 9;
const float sensorInterrupt = 1;
  lcd.begin(16, 2);
 timeoutCounter = 0;
void sensorIsr()
  lcd.setCursor(0,0);
   --timeoutCounter;
float Ppsi = ((sensorVoltage-105)/204)*12.5;
float Fpsi = ((sensorVoltage2-115)/204)*12.5;
float DpsiBar = (Ppsi-Fpsi);
float PDL = ((sensorVoltage3)/1023)*10;
if (DpsiBar >= PDL)
//------------------------------------------------Fuel Level
float sensorVoltage4 = analogRead(3);   // read the sensor voltage from analog pin 2 for Max Pressure Difference
float FLEV = ((sensorVoltage4)/1023)*10;
  switch (page) {
    case 0:
lcd.print (rpm, 1);
lcd.print (" RPM");
delay (1000);
    case 1:
lcd.print (Ppsi,1);
lcd.print (" BAR");
delay (500);
    case 2:
lcd.print (Fpsi,1);
lcd.print (" BAR");
delay (500);
    case 3:
lcd.print (Dpsi);
lcd.print (" % ");
lcd.print (" BAR");
delay (500);
    case 4:
lcd.print (PDL,1);
lcd.print (" BAR");
delay (500);
    case 5:
lcd.print ("Fuel Level");
lcd.print (FLEV,1);
lcd.print (" BAR");
delay (100);
    delay(500);               // if the state has changed, increment the counter
    lcd.clear();
      if(page==6)
        page=0;
i can not understand why it is not working on pin 10
also the tachometer in case there is no pulse it does not goes to 0 but still showing the last value and waiting for a pulse, any idea how can i move the value to zero in case there is no pulse?
Please read what attachInterrupt() has to say about which pins are used by which interrupts on a Uno
You cannot use pin 10 on a Uno as an external interrupt pin
Save the time from millis() when the tacho interrupt occurs. Then, each time through loop() test how long has elapsed since the last saved time. If it exceeds say 1 second (but you decide) then write zero to the display
UKHELIBOB
you are very polite and thanks for let me know , i just read that i can not use that pin, thanks again.
can you please let me know how can i count the time and write zero on the screen ???
thank you veyr much, i really appreciate your help
Declare 3 new global unsigned long variables
startTime, currentTime and period. Give period a value of 1000 for now. The others don't need to be initialised with a value.
In the ISR put
startTime = millis();  //save the time the tacho was read
Somewhere in loop() put
currentTime = millis();
if (currentTime - startTime >= period)  //test whether the tacho value was read recently
  //code here to write 0 to the display
Change the value of period (milliseconds) to change how soon the zero should be displayed
ukhelibob,
i did that but i get an error
 timeoutCounter = 0;
void sensorIsr()
  lcd.setCursor(0,0);
   --timeoutCounter;
if (currentTime - startTime >= 1500)  //test whether the tacho value was read recently
  lcd.print("0");
error
DigitalReadSerial:71: error: 'currentTime' was not declared in this scope
exit status 1
'startTime' was not declared in this scope
Read post # 13
Did you
UKHlebob
as i wrote them below??? it does not work like that :frowning:
int inPin = 8;
int page = 0;
int inPinOut = 9;
unsigned long startTime;
unsigned long currentTime;
unsigned long period = (1000);
  lcd.begin(16, 2);
 timeoutCounter = 0;
void sensorIsr()
 startTime = micros();  //save the time the tacho was read
  lcd.setCursor(0,0);
   --timeoutCounter;
  int rpm = 0;
If you Auto Format the code in the IDE you will (may) spot that there is no closing brace on the loop() function.
Also, remove the brackets around the 1000 in the declaration of period. I only used them in my post to clue you into the fact that the value for period was in milliseconds.
i did that but still did not works
LiquidCrystal lcd(12, 11, 7, 6, 5, 4);
int inPin = 8;
int page = 0;
int inPinOut = 9;
unsigned long period = 1000;
    lcd.begin(16, 2);
  timeoutCounter = 0;
void sensorIsr()
  lcd.setCursor(0, 0);
    --timeoutCounter;
  float rpm = 60e6 / (float)interval;
    float rpm = 0;
  float Ppsi = ((sensorVoltage - 105) / 204) * 12.5;
  float Fpsi = ((sensorVoltage2 - 115) / 204) * 12.5;
  float DpsiBar = (Ppsi - Fpsi);
  int Dpsi = ((DpsiBar * 100) / Ppsi);
  float PDL = ((sensorVoltage3) / 1023) * 10;
  if (DpsiBar >= PDL)
  float FLEV = ((sensorVoltage4) / 1023) * 10;
  switch (page) {
    case 0:
      lcd.setCursor (0, 1);
      lcd.print (rpm, 1);
      lcd.print (" RPM");
      delay (1000);
    case 1:
      lcd.print (Ppsi, 1);
      lcd.print (" BAR");
      delay (500);
    case 2:
      lcd.print (Fpsi, 1);
      lcd.print (" BAR");
      delay (500);
    case 3:
      lcd.print (Dpsi);
      lcd.print (" % ");
      lcd.print (" BAR");
      delay (500);
    case 4:
      lcd.print (PDL, 1);
      lcd.print (" BAR");
      delay (500);
    case 5:
      lcd.print (FLEV, 1);
      lcd.print (" BAR");
      delay (100);
      lcd.clear();
      if (page == 6)
        page = 0;
Does it compile ? What does it do when it runs ?
Which pin is the tacho attached to ?
Why double braces ?
  lastPulseTime = micros();Did you mean to use millis() ?
input or output ?
