problem with the W5100 device
Hello everyone, have a good day, I'm new to the forum. I am working on some projects to develop smart home systems with arduino. I use Arduino uno, ethernet shield and teleduino structures in it. but i am having a problem with the wiznet w5100 device. I use vdsl modem (VMG3312-B10B) and switch (EP-808SX-C) devices at home. I program the arduino device with the teleduino sample code and start the testing process. I do the test operations through teleduino api.
everything works properly when I connect modem <-> ethernet <-> w5100. but when i connect with modem <-> ethernet <-> switch <-> ethernet <-> w5100, i can't access teleduino api.
It seems that the assignment of the ip is done on the main page of the modem, but this screen is only visible when a direct connection between the modem and the w5100 is provided. I send a ping through windows cmd and everything looks fine.
however, when I connect the w5100 device with a switch, the connection information on the modem interface is lost.
my source codes:
  Teleduino328EthernetClientProxy.ino - Teleduino328EthernetClientProxy example
  Version 328-0.6.9
  Nathan Kennedy 2009 - 2014
  http://www.teleduino.org
  This sketch is distributed in the hope that it will be useful,
  but WITHOUT ANY WARRANTY; without even the implied warranty of
  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
#include <EEPROM.h>
#include <Servo.h>
#include <Wire.h>
#include <Teleduino328.h>
#include <SPI.h>
#include <Ethernet.h>
// User configurable variables
byte useDhcp = true;
byte useDns = true;
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress deviceIp(192, 168, 1, 57); // Only if useDhcp is false
IPAddress gatewayIp(192, 168, 1, 1); // Only if useDhcp is false
IPAddress dnsIp(192, 168, 1, 1); // Only if useDhcp is false
IPAddress subnet(255, 255, 255, 0); // Only if useDhcp is false
IPAddress serverIp(173, 230, 152, 173); // Only if useDns is false
char serverName[] = "us01.proxy.teleduino.org"; // Only if useDns is true
unsigned int serverPort = 5353; // Can be set to either 53 or 5353
byte statusLedPin = 8;
// User configurable key, this is used to authenticate with the proxy server
// This is checked against the EEPROM on boot and written if necessary
// The proxy server retreives the key from the EEPROM
byte key[] = { 0xE3, 0x11, 0xD2, 0x41,
               0xE6, 0x5F, 0x6D, 0x6C,
               0x5B, 0x7A, 0x7C, 0x79,
               0xEB, 0x10, 0x64, 0xDE };
// E311D241E65F6D6C5B7A7C79EB1064DE -> API KEY
// Other required variables
byte data[257];
byte dataLength;
byte hexStage;
unsigned long lastInstruction = 0;
unsigned long lastRefresh = 0;
byte stage = 0;
// Declare client object
EthernetClient Client;
  // Load presets
  Teleduino328.loadPresets();
  // Set status LED pin
  Teleduino328.setStatusLedPin(statusLedPin);
  Teleduino328.setStatusLed(1); // Initialisation
  // Check the EEPROM header and check to see if the key is correct
  // This is to ensure the key is not cleared from the EEPROM
  if(EEPROM.read(0) != '#')
    EEPROM.write(0, '#');
  if(EEPROM.read(1) != 0)
    EEPROM.write(1, 0);
  if(EEPROM.read(2) != '#')
    EEPROM.write(2, '#');
  if(EEPROM.read(160) != '#')
    EEPROM.write(160, '#');
  for(byte i = 0; i < 16; i++)
    if(EEPROM.read(161 + i) != key[i])
      EEPROM.write(161 + i, key[i]);
  if(EEPROM.read(177) != '#')
    EEPROM.write(177, '#');
  // Start network and attempt to connect to proxy server
  Teleduino328.setStatusLed(2); // Network configuration
  if(useDhcp)
    if(!Ethernet.begin(mac))
      Teleduino328.setStatusLed(2, false, 10000);
      Teleduino328.reset();
    Ethernet.begin(mac, deviceIp, dnsIp, gatewayIp, subnet);
  Teleduino328.setStatusLed(3); // Connect to server
  if((useDns && !Client.connect(serverName, serverPort)) || (!useDns && !Client.connect(serverIp, serverPort)))
    Teleduino328.setStatusLed(3, false, 10000);
  lastInstruction = millis();
  if(Client.connected())
    // What we need to do depends on which 'stage' we are at
    switch(stage)
      case 0: // Wait for start byte
        if(Client.available())
          char c = Client.read();
          if(c == '?')
            stage++;
      case 1: // Reset variables
        dataLength = 0;
        hexStage = 0;
        stage++;
      case 2: // Instruction byte
          if(c == '?')
            stage = 1;
          else if(c == '\r' || c == '\n' || c == '.')
            stage = 0;
          if(!hexStage)
            data[0] = Teleduino328.hexDecode(c) * 16;
            data[0] += Teleduino328.hexDecode(c);
          hexStage = !hexStage;
          if(!hexStage)
            stage++;
      case 3: // Data length byte
          if(c == '?')
            stage = 1;
            stage = 0;
          if(!hexStage)
            data[1] = Teleduino328.hexDecode(c) * 16;
            data[1] += Teleduino328.hexDecode(c);
          if(!hexStage)
            stage++;
      case 4: // Data
          if(c == '?')
            stage = 1;
            if(dataLength == data[1])
              stage++;
              stage = 0;
          if(!hexStage)
            data[2 + dataLength] = Teleduino328.hexDecode(c) * 16;
            data[2 + dataLength] += Teleduino328.hexDecode(c);
          if(!hexStage)
            dataLength++;
      case 5: // Execute instruction and return result
        Teleduino328.instruction(data);
        Client.write('!');
        for(int i = 0; i < data[1] + 2; i++)
          Client.write(Teleduino328.hexEncode(data[i] / 16));
          Client.write(Teleduino328.hexEncode(data[i] % 16));
        Client.write('\n');
        stage = 0;
    Teleduino328.setStatusLed(10);
  // Has the instruction timeout been reached?
  if(millis() - lastInstruction > 30000)
    Client.flush();
    Client.stop();
    Teleduino328.setStatusLed(9);
  // Process refreshes every 50ms
  if(millis() - lastRefresh >= 50)
    Teleduino328.pinTimers();
    Teleduino328.shiftRegisterTimers();
    Teleduino328.shiftRegisters();
    lastRefresh = millis();
  // Check to see if reset has been requested
  Teleduino328.checkReset();
So as a result, I cannot use the w5100 with a switch. How should I proceed to solve this problem? Thank you.
As you failed to provide a link to your WizNet5100 device I guess it isn't an original Arduino Ethernet Shield. Many cheap Chinese boards have wrong resistors soldered onto the board that let them fail if the opposite device does auto negotiation (which the switch most probably does).
I think there have been issues with the ethernet boards and switches in the past. You might try searching the upper right of this page for "switch", but it seems to be FUBAR at the current time, so a google site search might work.
