Problem with time library
Hi!
I would like to compare time in if statment like: if((current_hour == alarm_hour)&&(current_minute == alarm_minute)) I know that i could use Time alarm library but i m runing out of space on arduino nano so time alarm library is not ok for me.
Thank you for your answer. :)
Where are the 4 variables used in the comparison coming from ?
So i alredy found bigger problem, that i can not set up time using int variables setTime(int,int,int,int,int,int)
becouse int does not allow leading zero in front of a number.
Does anybody know how to set up time different way.
Glavna.ino (8.89 KB)
What type of variables does the setTime() function take as its parameters ?
The printing of leading zeros should surely be handled by the display routine
