Problem with time sensitive coding
I'm trying to make an audio spectrum analyzer using 2 arduino UNO's and an RGB LED Matrix. The first arduino takes in an analog audio signal and runs it through a DFT algorithm. The second arduino gets the DFT output from the first arduino using I2C and visualizes the data on the LED matrix.
Sender code:
#include <Wire.h>
#define cbi(sfr, bit) (_SFR_BYTE(sfr) &= ~_BV(bit))
#define sbi(sfr, bit) (_SFR_BYTE(sfr) |= _BV(bit))
  Wire.begin();
  sbi(ADCSRA, ADPS2);
  cbi(ADCSRA, ADPS1);
  cbi(ADCSRA, ADPS0);
  int N=512;
  int x[N];
  long t, t0, k, k0;
  int j=0;
  float X_Ret, X_Imt, X_Re, X_Im,X_Mag;
  float wrt[32];
  //t0 = micros();
  byte randData[32];
  byte outData[32];
  for(int i=0 ; i<32 ; i++){
    if(i<10){
      randData[i] = random(0,4);
    else if(i<20){
      randData[i] = random(0,10);
    else{
      randData[i] = random(0,16);
  for(int i=0 ; i<N ; i++){
    x[i] = analogRead(0)-512;
    //delayMicroseconds(29);
  //t = micros()-t0;
  /*Serial.print("Time per sample: ");
  Serial.println((float)t/N);
  Serial.print("Frequency: ");
  Serial.println((float)N*1000000/t);*/
  t0 = micros();
  //DFT start
  for(int m=1 ; m<255 ; m+=8){
    X_Re=0;
    X_Im=0;
    for(int n=0 ; n<N ; n++){
      X_Ret=x[n]*(cos(6.28*m*n/N));
      X_Imt=x[n]*(sin(6.28*m*n/N));
      X_Re = X_Re + X_Ret;
      X_Im = X_Im - X_Imt;
    wrt[j]=sqrt(X_Re*X_Re+X_Im*X_Im);
    if(wrt[j]>3200){
      wrt[j]=3200;
    outData[j]=round(wrt[j]*15/3200);
    j++;
  //DFT end
  t = micros()-t0;
  Serial.println(t);
  Wire.beginTransmission(8);
  Wire.write(randData,32);
  Wire.endTransmission();
  /*t = micros()-t0;
  Serial.println(t);*/
  //delay(1000);
Receiver code:
#include <Adafruit_GFX.h>
#include <RGBmatrixPanel.h>
#include <Wire.h>
#define CLK 8
#define LAT A3
#define OE  9
#define A   A0
#define B   A1
#define C   A2
RGBmatrixPanel matrix(A, B, C, CLK, LAT, OE, false);
  matrix.begin();
  Wire.begin(8);
  Wire.onReceive(receiveEvent);
void receiveEvent(int howMany) {
  int i=0;
  uint8_t x,y;
  int h[32];
  while (0 < Wire.available()) {
    h[i] = Wire.read();
    i++;
  matrix.fillScreen(0);
  for(x=0;x<32;x++){
    for(y=0;y<=h[x];y++){
      matrix.drawPixel(x, y, matrix.Color333(7, 0, 0));
  matrix.swapBuffers(false);
If you run this code everything works fine. I've printed the time the DFT algorithm takes to the serial monitor and it takes about 4 microseconds. However I'm just sending a randomly generated dataset called 'randData' to the second arduino. What i really want to send to the second arduino is 'outData', but when i change Wire.write(randData,32); to Wire.write(outData,32); the DFT algorithm now takes almost 5 seconds to run which is way to long to have a decent refresh rate on my LED matrix.
If you want to test this you don't need to have a second arduino with LED matrix attached to it. Just run the sender code on a standalone arduino and check the time the DFT algorithm takes with the serial monitor.
64 clock cycles?
I'm amazed.
DiscartDismay:
but when i change
to
I wonder if the compiler has been too clever for you and has completely eliminated all the code associated with outData in the case where you are not using the data? In the test where you DON'T use outData try defining outData as
volatile byte outData[32];
...R
Robin2:
...R
This seems to be the case, when I define outData as volatile the DFT algorithm also takes about 5 seconds.
A 16MHz processor is going to struggle t process audio. Perhaps you could capture a chunk at a time, computing as fast as it may in between chunks.
Even then - you realize that using analogRead takes time? AFAIK, analogRead works by timing a capacitor discharge.
analogRead works by going through ten cycles of binary chop, each cycle consisting of outputting a voltage, and comparing the input voltage to it.
This doesn't run at processor cycle speed.
(Google "successive approximation converter")
PaulMurrayCbr:
That's why I used
  Wire.begin();
  sbi(ADCSRA, ADPS2);
  cbi(ADCSRA, ADPS1);
  cbi(ADCSRA, ADPS0);
This changes the prescaler from the ADC from 128 to 16 to allow faster reading speeds. I can sample at about 66 kHz wich is enough for audio.
Quite a bit longer than that, if you measure the time correctly. Just calculating sin(x) takes about 120 us on the Uno.
Try the OpenMusicLabs FFT (or faster, the FHT) which are coded partly in assembler.
Move up to a Teensy and the PJRC Audio Libray.
jremington:
Surely you'd precalculate the sines and cosines and stick them in a table? Another thing to do is use fixed-point rather than floating point arithmetic.
